[solved] Tab height
JanEeBra
[solved] Tab height
Post by JanEeBra » Mon Nov 15, 2021 4:00 pm
Hi!
Is there any way to configure the height of tabs? When cutting foamboard that is corrugated on both sides, a tab ending up in a thin section of the board is completely lost!
Re: Tab height
Post by andrew » Mon Nov 15, 2021 5:10 pm
While creating a tab, you can set its thickness in the options toolbar:
Screenshot 2021-11-15 at 17.09.21.png (12.05 KiB) Viewed 3805 times
You can also adjust this later for one or multiple selected tabs in the property editor.
JanEeBra
Re: Tab height
Post by JanEeBra » Mon Nov 15, 2021 6:48 pm
I had completely missed that! Thank you!
Return to “QCAD/CAM”
