CAM output text formatting?
Dacicusan
Post by Dacicusan » Fri Jan 28, 2022 5:51 pm
Hi. I do need to write a new post-processor for a Morbidelli machine and I do need the following output format:
I want to change in the post.js (modified from the "EMC2.js") the following line:
this.rapidMove = "G0 [X] [Y]";
to have this output:
XG0 X=765 Y=5 Z=15.2 V=1500 S=18000 D=10 T=107 C=1 E=1
The problem is that I don'ow how to change the
[X]
part to have as output:
X=765
(765 is the value of X).
Unfortunately the documentation on how to create a new post-processor it is very scarce and I can't find a way how to get the desired output. Thank you.
Re: CAM output text formatting?
Post by CVH » Fri Jan 28, 2022 6:19 pm
It can't be the idea that all traversing in G0 mode would go to (765.0,5.0) ... :roll:
Means that all rapid moves will be coded as 'G0' literal and the parsed coordinate in X & Y with spaces in between.
With 'G0' in standard G-code meaning 'as fast as allowed'.
[X] & [Y] are placeholders for the X and the Y coordinate of the CAM output.
These variables are declared elsewhere.
The values may vary depending the path to follow.
For the rapid moves to start with 'XG0' literal instead of 'G0' literal:
this.rapidMove = "XG0 [X] [Y]";
For extra things just add them literal:
this.rapidMove = "XG0 X=[X] Y=[Y] Z=[Z] V=1500 ... and so on";
In this case for rapid moves: V will always be 1500, S always 18000, ...
Dacicusan
Post by Dacicusan » Fri Jan 28, 2022 7:14 pm
It is not working. I do get this:
XG0 X=[] Y=[]
And I need the values of X and Y instead of the square brackets. Like this:
XG0 X=765 Y=5
Post by CVH » Sat Jan 29, 2022 4:21 am
"XG0 X=[] Y=[]"
Ok, so the "XG0" works out but the rest isn't ... :(
Dug a little deeper and I think I may see my mistake. :oops:
Look up where your variable is defined e.g.
    //                    name,                  ID,                     always, prefix, decimals, options
    this.registerVariable("xPosition",           "X",                    false, "X", "DEFAULT", "DEFAULT");
Adapt the prefix
So that the placeholder '[X]' is replaced by the 'xPosition' with prefix 'X=' ...
Other literal things should work out. Are they?
Dacicusan
Post by Dacicusan » Tue Feb 01, 2022 12:28 pm
Now I have:
XG0 X=[xPosition] Y=[yPosition]
in the output
Post by CVH » Tue Feb 01, 2022 12:50 pm
Now I have:
in the output
:shock:
Please include your custom post processor in full.
As a *.js file or as code is fine.
And all related custom things like a test drawing with CAM profiles.
Or adapted base classes.
Dacicusan
Post by Dacicusan » Tue Feb 01, 2022 1:04 pm
I just changed a post that already exists and smashing my head against the walls because I have no idea about programming.
This is the output from AlphaCAM:
H DX=2440 DY=1220 DZ=15 -EH C=0 T=16973824 R=1 *MM /"DEF" BX=0 BY=0 BZ=6 V=0; BACKWALL_ALPHACAM
* Tool List Start
;Tool=107. Name=E07 10MM SPIRAL ,Diameter=8.2
;Tool=8. Name=E08 - 7.5MM DRILL RH ,Diameter=7.5
* Tool List End
.OP1 ;Cut_Through
XL2P X=5 Y=5 V=4000
XL2P X=5 Y=895
XL2P X=1525 Y=895
XL2P X=1525 Y=5
XL2P X=765 Y=5
.OP2 ;Cut_Through(3)
XG0 X=339 Y=177.5 Z=15.2 V=1500 S=18000 D=10 T=107 C=2 E=1
XL2P X=339 Y=165 V=4000
XL2P X=314 Y=165
XL2P X=314 Y=190
XL2P X=339 Y=190
XL2P X=339 Y=177.5
.OP3 ;Drill_Through_7.5(12)
XB X=316.652 Y=187.348 Z=0 T=8 V=4000 F=1
XB X=336.348 Y=187.348 Z=0 T=8 V=4000 F=1
XB X=336.348 Y=167.652 Z=0 T=8 V=4000 F=1
XB X=316.652 Y=167.652 Z=0 T=8 V=4000 F=1
XN X=612 Y=0
I just used a Milling bit (107) and a drilling one (8).
BZ=6 is the thickness of the spoilboard. The "DX=2440 DY=1220 DZ=15" are the raw material dimensions to cut from.
SCM.js
(1.91 KiB) Downloaded 1974 times
_BackWall.dxf
(242.58 KiB) Downloaded 1915 times
Dacicusan
Post by Dacicusan » Tue Feb 01, 2022 1:10 pm
And here is the output from SCM Maestro if I import the dxf file:
H DX=2440.000 DY=1220.000 DZ=15.000 -EH C=0 T=16973824 R=1 *MM /"def" BX=0.000 BY=0.000 BZ=6.000 V=0
; >> Definizione di variabili ed espressioni
; >> Post P. Release...
;Versione : 1.00.015.1010;
; >> Descrizione del programma...
; Data di creazione: 2/1/2022 12:07:47 PM
; >> Utensili utilizzati...
; >> Inizio Programma...
;Setup del pezzo Piece sulla fase Setup
REF DX=2440.000 DY=1220.000 DZ=15.000 FLD=EH BX=0.000 BY=0.000 BZ=0.000
.OP1 ;Cut_Through
F=1
O X=0.000 Y=0.000 Z=0.000 F=1 ;ChangePlane
SET ZFAST=20.000
XG0 X=765.000 Y=325.000 Z=15.200 T=107 P=0 D=20 C=1 E=1 s=0
XL2P X=5.000 Y=325.000 Z=15.200 V=4000
XL2P X=5.000 Y=1215.000 Z=15.200 V=4000
XL2P X=1525.000 Y=1215.000 Z=15.200 V=4000
XL2P X=1525.000 Y=325.000 Z=15.200 V=4000
XL2P X=765.000 Y=325.000 Z=15.200 V=4000
.OP2 ;Cut_Through(1)
XG0 X=326.500 Y=1030.000 Z=15.200 T=107 P=0 D=20 C=1 E=1 s=0
XL2P X=339.000 Y=1030.000 Z=15.200 V=4000
XL2P X=339.000 Y=1055.000 Z=15.200 V=4000
XL2P X=314.000 Y=1055.000 Z=15.200 V=4000
XL2P X=314.000 Y=1030.000 Z=15.200 V=4000
XL2P X=326.500 Y=1030.000 Z=15.200 V=4000
XB X=316.652 Y=1032.652 Z=15.200 T=008 G=1 V=4000.000 S=8000.000
.OP4 ;Drill_Through_7.5(1)
XB X=336.348 Y=1032.652 Z=15.200 T=008 G=1 V=4000.000 S=8000.000
.OP5 ;Drill_Through_7.5(2)
XB X=336.348 Y=1052.348 Z=15.200 T=008 G=1 V=4000.000 S=8000.000
.OP6 ;Drill_Through_7.5(3)
XB X=316.652 Y=1052.348 Z=15.200 T=008 G=1 V=4000.000 S=8000.000
PARK S=0
.END
;FINEPROG
Post by CVH » Tue Feb 01, 2022 2:04 pm
Line 12 should read:
    this.registerVariable("xPosition", "X", false, "X=", "DEFAULT", "DEFAULT");
add also:
    this.registerVariable("yPosition", "Y", false, "Y=", "DEFAULT", "DEFAULT");
    this.registerVariable("zPosition", "Z", false, "Z=", "DEFAULT", "DEFAULT");
That should export XYZ values as X=... Y=... and so on.
I also see that standard G-code F for feed isn't used ...
So also include:
    this.registerVariable("feedRate",            "F",                    false, "V=", 0);
    this.registerVariable("plungeRate",          "FP",                   false, "V=", 0);
Feeds would than be exported as V=....
Look up in GCodeBase.js what can by 'translated' further.
Don't edit that file, include it in yours :!:
Line 35-36 should read:
    this.rapidMoveZ =                 "XG0 [Z]";
That uses your 'XG0' format instead of the standard 'G0'.
The prefixes for XYZ are handled above. :wink:
It is not common to do a G0 move to a coordinate with Z.
One usually moves up to safety height and then moves in the XY plane.
Plunging down is usually a G1 move or a combination of G0 and G1.
But in fact, what you need is not standard G-code at all.
I can't help you with what 'XL2P' would be.
'XB' looks like drilling. In G-code that is G0 to XY, G0 to clearance level, G1 to drill, G0 to withdraw ...
Or using canned cycles e.g. G81/82 ...
Bottom line ... Your machine is programmed using macros.
These macros are internally translated in G-codes. :wink:
Can it handle G-codes in direct :?:
Probably it will ... 8)
Claudiosp
Post by Claudiosp » Sat Sep 10, 2022 1:32 pm
HI
Look this.
SCM.js
(2.89 KiB) Downloaded 1840 times
Dacicusan
Post by Dacicusan » Wed May 15, 2024 1:51 pm
Thank you for sharing this. Just now I saw your reply!
Return to “QCAD/CAM”
