Thinking of purchasing QCAD/CAM some quetsions
disaldo
Post by disaldo » Mon Mar 06, 2023 3:01 pm
Hello
I purchased QCAD back in 2018 to do some small 2D flightsim panels on my CNC, as with a lot of hobbies life takes over and things get put on hold. Now its 2023 I want to get back to making these panels and upgrading my cnc to a larger bed size. My questions are as follows and any help would be gratefully received :)
Are there any restrictions on the size of the piece of work for example Vectric 2D desktop is 600 mm by 600mm
With the CAM aspects is there a manual as there is with the CAD aspects.
Is the program UI windows based ie windows as in UI and not OS , there seems to be very little screen shots around,
I see a lot of comments about writing code does the program do this for you.
Apologies if these seem dumb questions but other alternative software seem to be ridiculously expensive and really bloated for what I am trying to achieve.
Thanks in advance
Stephen
Re: Thinking of purchasing QCAD/CAM some quetsions
Post by CVH » Mon Mar 06, 2023 4:38 pm
Not that I am aware of. The QCAD/CAM trial version is limited in its export.
Not that I am aware of. You can get help by posting in this forum.
Mostly, I find QCAD very intuitive, but from time to time there are those things that need a bit more explanation.
Look up some keywords or just post your problem and/or question.
QCAD is especially written to be portable over a range of different OS and versions.
Most obvious from the trial download page: https://www.ribbonsoft.com/en/download
True, 5 example screenshots is not much: https://www.ribbonsoft.com/en/documentation/gallery
QCAD has a complete API and supports scripting in ECMAScript and in C++.
What we don't can do with the standard tools can probably be done with a custom script.
Your imagination is there the limit.
And no, QCAD doesn't write any code but QCAD/CAM can export geometry in different ways and that includes G-Code.
There are many flavors of G-code and QCAD/CAM post-processors can be customized.
There are no dumb questions to my knowledge.
disaldo
Post by disaldo » Mon Mar 06, 2023 9:37 pm
CVH. thanks for the response all makes sense.
Regards
Stephen
Return to “QCAD/CAM”
