does anybody know how to program a line-thickness of 1.3mm and 4mm in Qcad.
I tried this in the Linetypes-folder but that didnt work.
Thank you for the help!
Greetz, Emiel
Line thickness
Re: Line thickness
Please have a look at this tutorial about custom line weights:
https://qcad.org/en/tutorial-custom-lineweights
Re: Line thickness
Hello and thank you for the quick reply Andrew.
As a newbie i work with the free version of Qcad.
Is the "Global width" a feature in the Profesional edition?
Thank you,
Emiel
Thank you,
Emiel
Re: Line thickness
Yes, unfortunately it is only available in the QCAD Professional version ...Emiel Bosch wrote: ↑Mon Feb 22, 2021 8:44 pmIs the "Global width" a feature in the Profesional edition?
This list will show you the differences between the QCAD Community- and the Profession Edition ...
https://www.qcad.org/en/documentation/features
Re: Line thickness
I'll move this topic to the QCAD Community forum. You've posted to the QCAD Professional forum.
Re: Line thickness
Husky and Andrew, thanx for the help.
Qcad is an excellent program, i will be glad spending money on this program.
Greetz, Emiel
Greetz, Emiel
