Crashed on undo
SQLGuy
Crashed on undo
Post by SQLGuy » Sun Aug 20, 2023 8:10 pm
Had this happen when I hit ctrl-Z a couple of times:
Translated Report (Full Report Below)
Process: QCADCAM-Trial [15580]
Path: /Applications/QCADCAM-Trial.app/Contents/MacOS/QCADCAM-Trial
Identifier: org.qcad
Version: 3.28 (3.28.1)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-08-20 13:08:35.2146 -0600
OS Version: macOS 12.6.7 (21G651)
Report Version: 12
Bridge OS Version: 3.0 (14Y910)
Anonymous UUID: 6D29E7C9-26E8-9FD8-DCD5-041590AF113E
Sleep/Wake UUID: 0CDBF215-E61A-41CE-AB0D-9260C8CD0405
Time Awake Since Boot: 220000 seconds
Time Since Wake: 76840 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000018
Exception Codes: 0x0000000000000001, 0x0000000000000018
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [15580]
VM Region Info: 0x18 is not in any region. Bytes before following region: 140737486852072
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
VM_ALLOCATE 7fffffe91000-7fffffe92000 [ 4K] r-x/r-x SM=ALI
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libqcadcore.dylib 0x10e80b035 RTransaction::undo() + 389
1 libqcadcore.dylib 0x10e811faf RTransactionStack::undo() + 143
2 libqcadcore.dylib 0x10e703a42 RDocument::undo() + 18
3 libqcadcore.dylib 0x10e712340 RDocumentInterface::undo() + 48
4 libqcadecmaapi.dylib 0x10f6714a6 REcmaDocumentInterface::undo(QScriptContext*, QScriptEngine*) + 246
5 QtScript 0x111c3c8bd 0x111abd000 + 1571005
6 QtScript 0x111b985d2 0x111abd000 + 898514
7 QtScript 0x111b7c154 0x111abd000 + 782676
8 ??? 0x487a3dc9caac ???
9 QtScript 0x111b0cc91 0x111abd000 + 326801
10 QtScript 0x111bb7778 0x111abd000 + 1025912
11 QtScript 0x111c39cf7 QScriptValue::call(QScriptValue const&, QList<QScriptValue> const&) + 631
12 libqcadecmaapi.dylib 0x10fe5753d REcmaShellActionAdapter::beginEvent() + 477
13 libqcadcore.dylib 0x10e70d440 RDocumentInterface::setCurrentAction(RAction*) + 512
14 libqcadecmaapi.dylib 0x10f668723 REcmaDocumentInterface::setCurrentAction(QScriptContext*, QScriptEngine*) + 307
15 QtScript 0x111c3c8bd 0x111abd000 + 1571005
16 QtScript 0x111b985d2 0x111abd000 + 898514
17 QtScript 0x111b7c154 0x111abd000 + 782676
18 ??? 0x487a3dd23fb4 ???
19 QtScript 0x111b0b55e 0x111abd000 + 320862
20 QtScript 0x111b0d721 0x111abd000 + 329505
21 QtScript 0x111c237a9 0x111abd000 + 1468329
22 QtScript 0x111c27830 QScriptEngine::evaluate(QString const&, QString const&, int) + 352
23 libqcadecmaapi.dylib 0x10f428c68 RScriptHandlerEcma::eval(QString const&, QString const&) + 40
24 libqcadecmaapi.dylib 0x10f429e5b RScriptHandlerEcma::createActionDocumentLevel(QString const&, RGuiAction*, RDocumentInterface*) + 1243
25 libqcadcore.dylib 0x10e7602cc RGuiAction::slotTrigger(QString const&) + 524
26 libqcadcore.dylib 0x10e87de0d RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 141
27 QtCore 0x112524bd5 0x1122fc000 + 2264021
28 QtWidgets 0x110f0c716 QAction::activate(QAction::ActionEvent) + 310
29 QtCore 0x11251ccff QObject::event(QEvent*) + 943
30 QtWidgets 0x110f15f5a QApplicationPrivate::notify_helper(QObject*, QEvent*) + 266
31 QtWidgets 0x110f173e6 QApplication::notify(QObject*, QEvent*) + 598
32 QtCore 0x1124f19f4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
33 QtCore 0x1124f2be9 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 809
34 libqcocoa.dylib 0x111d040e9 0x111ccb000 + 233705
35 libqcocoa.dylib 0x111d04858 0x111ccb000 + 235608
36 CoreFoundation 0x7ff81bc4715b __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
37 CoreFoundation 0x7ff81bc470c3 __CFRunLoopDoSource0 + 180
38 CoreFoundation 0x7ff81bc46e3d __CFRunLoopDoSources0 + 242
39 CoreFoundation 0x7ff81bc45858 __CFRunLoopRun + 892
40 CoreFoundation 0x7ff81bc44e1c CFRunLoopRunSpecific + 562
41 HIToolbox 0x7ff8248f55e6 RunCurrentEventLoopInMode + 292
42 HIToolbox 0x7ff8248f534a ReceiveNextEventCommon + 594
43 HIToolbox 0x7ff8248f50e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
44 AppKit 0x7ff81e67ff6d _DPSNextEvent + 927
45 AppKit 0x7ff81e67e62a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
46 AppKit 0x7ff81e670cd9 -[NSApplication run] + 586
47 libqcocoa.dylib 0x111d035d3 0x111ccb000 + 230867
48 QtCore 0x1124eda7f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
49 QtCore 0x1124f2002 QCoreApplication::exec() + 130
50 libqtscript_core.dylib 0x11754313f qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*) + 1535
51 QtScript 0x111c3c8bd 0x111abd000 + 1571005
52 QtScript 0x111b985d2 0x111abd000 + 898514
53 QtScript 0x111b7c154 0x111abd000 + 782676
54 ??? 0x487a3d831952 ???
55 QtScript 0x111b0b55e 0x111abd000 + 320862
56 QtScript 0x111b0d721 0x111abd000 + 329505
57 QtScript 0x111c237a9 0x111abd000 + 1468329
58 QtScript 0x111c27830 QScriptEngine::evaluate(QString const&, QString const&, int) + 352
59 libqcadecmaapi.dylib 0x10f428c68 RScriptHandlerEcma::eval(QString const&, QString const&) + 40
60 libqcadecmaapi.dylib 0x10f4281dd RScriptHandlerEcma::doScript(QString const&, QStringList const&) + 589
61 libqcadcore.dylib 0x10e7cf9f1 RScriptHandler::autostart(QString const&, QStringList const&) + 1857
62 QCADCAM-Trial 0x10db78a0e main + 5070
63 dyld 0x10dcb452e start + 462
Thread 1:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff81bb4bd4a __select + 10
1 CoreFoundation 0x7ff81bc6e659 __CFSocketManager + 641
2 libsystem_pthread.dylib 0x7ff81bb804e1 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff81bb7bf6b thread_start + 15
Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff81bb4396a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff81bb43cd8 mach_msg + 56
2 CoreFoundation 0x7ff81bc4734d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff81bc459d8 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff81bc44e1c CFRunLoopRunSpecific + 562
5 AppKit 0x7ff81e7ed98e _NSEventThread + 132
6 libsystem_pthread.dylib 0x7ff81bb804e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff81bb7bf6b thread_start + 15
Thread 3:
0 libsystem_pthread.dylib 0x7ff81bb7bf48 start_wqthread + 0
Thread 4:
Thread 5:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000011 rcx: 0x00006000034a8d50 rdx: 0x0000000000000022
rdi: 0x00007ff7b2390968 rsi: 0x0000000027d3f569 rbp: 0x00007ff7b23909d0 rsp: 0x00007ff7b23908b0
r8: 0x000000000000005a r9: 0x0000000000000083 r10: 0x00007f7aa6114a00 r11: 0xfffffffffffe74e0
r12: 0x00007ff7b2390968 r13: 0x00007ff7b23909e8 r14: 0x0000600001dac540 r15: 0x0000000000000002
rip: 0x000000010e80b035 rfl: 0x0000000000010246 cr2: 0x0000000000000018
Logical CPU: 6
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
48 8b 00 48 39 f8 0f 84-04 01 00 00 39 70 08 75 H..H9.......9p.u
ef 3b 48 0c 75 ea 48 39-f8 0f 84 f1 00 00 00 49 .;H.u.H9.......I
8b 75 10 48 8b 06 4c 89-e7 89 ca ff 90 30 01 00 .u.H..L......0..
00 48 8b 45 98[f6]40 18-01 0f 85 c5 05 00 00 48 [email protected] <==
8d 7d c0 4c 89 e6 e8 15-97 f8 ff 41 80 7d 56 00 .}.L.......A.}V.
0f 85 80 00 00 00 48 8b-4d c0 48 85 c9 74 77 49 ......H.M.H..twI
8b 06 48 8b 40 18 48 89-8d 38 ff ff ff 48 8b 4d [email protected]
c8 48 89 8d 40 ff ff ff-48 85 c9 74 0e f0 ff 01 [email protected]....
48 8b 8d 40 ff ff ff f0-ff 41 04 48 8b 0d fe 04 [email protected]....
30 00 48 89 4d d0 4c 89-f7 48 8d b5 38 ff ff ff 0.H.M.L..H..8...
48 8d 5d d0 48 89 da ff-d0 48 89 df e8 bf f0 ec H.].H....H......
ff 48 8b 9d 40 ff ff ff-48 85 db 74 19 f0 ff 4b [email protected]
Binary Images:
0x10e6ce000 - 0x10eb0afff libqcadcore.dylib (*) <630ebce2-f5d2-3bde-a31a-c53bc1ac8dfb> /Applications/QCADCAM-Trial.app/Contents/Frameworks/libqcadcore.dylib
0x10f3ef000 - 0x110634fff libqcadecmaapi.dylib (*) <a792a831-43c6-3dfa-bca6-c6b86456ec4c> /Applications/QCADCAM-Trial.app/Contents/Frameworks/libqcadecmaapi.dylib
0x111abd000 - 0x111c78fff org.qt-project.QtScript (5.14) <b2ce3701-570d-3a85-bba2-cff6b6ef2ad7> /Applications/QCADCAM-Trial.app/Contents/Frameworks/QtScript.framework/Versions/5/QtScript
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x1122fc000 - 0x11285afff org.qt-project.QtCore (5.14) <435c4ad2-bf9e-3561-93eb-041e7dab5fca> /Applications/QCADCAM-Trial.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x110f05000 - 0x111349fff org.qt-project.QtWidgets (5.14) <b4e7a5b5-9c2f-37fe-9b65-7ede8a80eea0> /Applications/QCADCAM-Trial.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x111ccb000 - 0x111e37fff libqcocoa.dylib (*) <0c163cef-1f43-3921-b089-07b7ee848d67> /Applications/QCADCAM-Trial.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x7ff81bbc7000 - 0x7ff81c0c9fff com.apple.CoreFoundation (6.9) <70b99b27-1b5b-33c4-b401-2ecdb80f3303> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff8248c7000 - 0x7ff824bbafff com.apple.HIToolbox (2.1.1) <06fdecd6-9f69-397b-b1e2-a8226c0ba7ed> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff81e641000 - 0x7ff81f4d0fff com.apple.AppKit (6.9) <1a1a9da7-da66-31da-92cd-51b9cf968145> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x11751a000 - 0x117722fff libqtscript_core.dylib (*) <4bc5f9ad-fd59-3fc6-8b8e-54970b4d090b> /Applications/QCADCAM-Trial.app/Contents/PlugIns/script/libqtscript_core.dylib
0x10db6c000 - 0x10db7bfff org.qcad (3.28) <26e81ca6-4593-3769-b6b7-8a9bb876a886> /Applications/QCADCAM-Trial.app/Contents/MacOS/QCADCAM-Trial
0x10dcaf000 - 0x10dd1afff dyld (*) <2517e9fe-884a-3855-8532-92bffba3f81c> /usr/lib/dyld
0x7ff81bb42000 - 0x7ff81bb79fff libsystem_kernel.dylib (*) <d0b338e0-26be-371b-a819-80b7d619a4ad> /usr/lib/system/libsystem_kernel.dylib
0x7ff81bb7a000 - 0x7ff81bb85fff libsystem_pthread.dylib (*) <e5d44afd-2577-3cee-8711-9d8d426229e0> /usr/lib/system/libsystem_pthread.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=2.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.7G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 896K 7
Activity Tracing 256K 1
CG backing stores 5408K 8
CG image 272K 22
ColorSync 228K 27
CoreAnimation 172K 12
CoreGraphics 16K 3
CoreUI image data 2588K 20
Foundation 16K 1
JS JIT generated code 128.0M 1
JS JIT generated code (reserved) 1.9G 1 reserved VM address space (unallocated)
JS VM Gigacage 20.0M 80
JS VM Isolated Heap 16.2M 4
Kernel Alloc Once 8K 1
MALLOC 273.2M 104
MALLOC guard page 32K 8
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
ObjC additional data 15K 1
STACK GUARD 56.0M 6
Stack 10.5M 6
VM_ALLOCATE 172K 26
WebKit Malloc 40.8M 55
__CTF 756 1
__DATA 22.7M 414
__DATA_CONST 15.7M 204
__DATA_DIRTY 753K 115
__FONT_DATA 4K 1
__LINKEDIT 663.6M 63
__TEXT 342.3M 424
__UNICODE 592K 1
dyld private memory 1056K 3
mapped file 449.7M 40
shared memory 804K 23
TOTAL 4.3G 1684
TOTAL, minus reserved VM space 2.0G 1684
Full Report
{"app_name":"QCADCAM-Trial","timestamp":"2023-08-20 13:08:45.00 -0600","app_version":"3.28","slice_uuid":"26e81ca6-4593-3769-b6b7-8a9bb876a886","build_version":"3.28.1","platform":1,"bundleID":"org.qcad","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.6.7 (21G651)","incident_id":"6A6AE316-D118-453B-BE59-BEDCD056DC4B","name":"QCADCAM-Trial"}
"uptime" : 220000,
"procLaunch" : "2023-08-20 12:58:28.9873 -0600",
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro13,3",
"procStartAbsTime" : 228704671096134,
"coalitionID" : 9492,
"osVersion" : {
"train" : "macOS 12.6.7",
"build" : "21G651",
"releaseType" : "User"
"captureTime" : "2023-08-20 13:08:35.2146 -0600",
"incident" : "6A6AE316-D118-453B-BE59-BEDCD056DC4B",
"bug_type" : "309",
"pid" : 15580,
"procExitAbsTime" : 229310898468463,
"cpuType" : "X86-64",
"procName" : "QCADCAM-Trial",
"procPath" : "\/Applications\/QCADCAM-Trial.app\/Contents\/MacOS\/QCADCAM-Trial",
"bundleInfo" : {"CFBundleShortVersionString":"3.28","CFBundleVersion":"3.28.1","CFBundleIdentifier":"org.qcad"},
"storeInfo" : {"deviceIdentifierForVendor":"4EF49AB5-7CB3-52DE-A7A2-BB52076B02DA","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "org.qcad",
"crashReporterKey" : "6D29E7C9-26E8-9FD8-DCD5-041590AF113E",
"wakeTime" : 76840,
"bridgeVersion" : {"build":"14Y910","train":"3.0"},
"sleepWakeUUID" : "0CDBF215-E61A-41CE-AB0D-9260C8CD0405",
"sip" : "enabled",
"vmRegionInfo" : "0x18 is not in any region. Bytes before following region: 140737486852072\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffe91000-7fffffe92000 [ 4K] r-x\/r-x SM=ALI ",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x0000000000000018","rawCodes":[1,24],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000018"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":15580},
"vmregioninfo" : "0x18 is not in any region. Bytes before following region: 140737486852072\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffe91000-7fffffe92000 [ 4K] r-x\/r-x SM=ALI ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":1471088,"instructionState":{"instructionStream":{"bytes":[72,139,0,72,57,248,15,132,4,1,0,0,57,112,8,117,239,59,72,12,117,234,72,57,248,15,132,241,0,0,0,73,139,117,16,72,139,6,76,137,231,137,202,255,144,48,1,0,0,72,139,69,152,246,64,24,1,15,133,197,5,0,0,72,141,125,192,76,137,230,232,21,151,248,255,65,128,125,86,0,15,133,128,0,0,0,72,139,77,192,72,133,201,116,119,73,139,6,72,139,64,24,72,137,141,56,255,255,255,72,139,77,200,72,137,141,64,255,255,255,72,133,201,116,14,240,255,1,72,139,141,64,255,255,255,240,255,65,4,72,139,13,254,4,48,0,72,137,77,208,76,137,247,72,141,181,56,255,255,255,72,141,93,208,72,137,218,255,208,72,137,223,232,191,240,236,255,72,139,157,64,255,255,255,72,133,219,116,25,240,255,75],"offset":53}},"threadState":{"r13":{"value":140701823732200},"rax":{"value":0},"rflags":{"value":66118},"cpu":{"value":6},"r14":{"value":105553147381056},"rsi":{"value":668202345},"r8":{"value":90},"cr2":{"value":24},"rdx":{"value":34},"r10":{"value":140164748888576},"r9":{"value":131},"r15":{"value":2},"rbx":{"value":17},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":18446744073709450464},"rip":{"value":4538282037,"matchesCrashFrame":1},"rbp":{"value":140701823732176},"rsp":{"value":140701823731888},"r12":{"value":140701823732072},"rcx":{"value":105553171483984},"flavor":"x86_THREAD_STATE","rdi":{"value":140701823732072}},"queue":"com.apple.main-thread","frames":[{"imageOffset":1298485,"symbol":"RTransaction::undo()","symbolLocation":389,"imageIndex":0},{"imageOffset":1327023,"symbol":"RTransactionStack::undo()","symbolLocation":143,"imageIndex":0},{"imageOffset":219714,"symbol":"RDocument::undo()","symbolLocation":18,"imageIndex":0},{"imageOffset":279360,"symbol":"RDocumentInterface::undo()","symbolLocation":48,"imageIndex":0},{"imageOffset":2630822,"symbol":"REcmaDocumentInterface::undo(QScriptContext*, QScriptEngine*)","symbolLocation":246,"imageIndex":1},{"imageOffset":1571005,"imageIndex":2},{"imageOffset":898514,"imageIndex":2},{"imageOffset":782676,"imageIndex":2},{"imageOffset":79689859844780,"imageIndex":3},{"imageOffset":326801,"imageIndex":2},{"imageOffset":1025912,"imageIndex":2},{"imageOffset":1559799,"symbol":"QScriptValue::call(QScriptValue const&, QList<QScriptValue> const&)","symbolLocation":631,"imageIndex":2},{"imageOffset":10913085,"symbol":"REcmaShellActionAdapter::beginEvent()","symbolLocation":477,"imageIndex":1},{"imageOffset":259136,"symbol":"RDocumentInterface::setCurrentAction(RAction*)","symbolLocation":512,"imageIndex":0},{"imageOffset":2594595,"symbol":"REcmaDocumentInterface::setCurrentAction(QScriptContext*, QScriptEngine*)","symbolLocation":307,"imageIndex":1},{"imageOffset":1571005,"imageIndex":2},{"imageOffset":898514,"imageIndex":2},{"imageOffset":782676,"imageIndex":2},{"imageOffset":79689860399028,"imageIndex":3},{"imageOffset":320862,"imageIndex":2},{"imageOffset":329505,"imageIndex":2},{"imageOffset":1468329,"imageIndex":2},{"imageOffset":1484848,"symbol":"QScriptEngine::evaluate(QString const&, QString const&, int)","symbolLocation":352,"imageIndex":2},{"imageOffset":236648,"symbol":"RScriptHandlerEcma::eval(QString const&, QString const&)","symbolLocation":40,"imageIndex":1},{"imageOffset":241243,"symbol":"RScriptHandlerEcma::createActionDocumentLevel(QString const&, RGuiAction*, RDocumentInterface*)","symbolLocation":1243,"imageIndex":1},{"imageOffset":598732,"symbol":"RGuiAction::slotTrigger(QString const&)","symbolLocation":524,"imageIndex":0},{"imageOffset":1768973,"symbol":"RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)","symbolLocation":141,"imageIndex":0},{"imageOffset":2264021,"imageIndex":4},{"imageOffset":30486,"symbol":"QAction::activate(QAction::ActionEvent)","symbolLocation":310,"imageIndex":5},{"imageOffset":2231551,"symbol":"QObject::event(QEvent*)","symbolLocation":943,"imageIndex":4},{"imageOffset":69466,"symbol":"QApplicationPrivate::notify_helper(QObject*, QEvent*)","symbolLocation":266,"imageIndex":5},{"imageOffset":74726,"symbol":"QApplication::notify(QObject*, QEvent*)","symbolLocation":598,"imageIndex":5},{"imageOffset":2054644,"symbol":"QCoreApplication::notifyInternal2(QObject*, QEvent*)","symbolLocation":212,"imageIndex":4},{"imageOffset":2059241,"symbol":"QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)","symbolLocation":809,"imageIndex":4},{"imageOffset":233705,"imageIndex":6},{"imageOffset":235608,"imageIndex":6},{"imageOffset":524635,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__","symbolLocation":17,"imageIndex":7},{"imageOffset":524483,"symbol":"__CFRunLoopDoSource0","symbolLocation":180,"imageIndex":7},{"imageOffset":523837,"symbol":"__CFRunLoopDoSources0","symbolLocation":242,"imageIndex":7},{"imageOffset":518232,"symbol":"__CFRunLoopRun","symbolLocation":892,"imageIndex":7},{"imageOffset":515612,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":7},{"imageOffset":189926,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":8},{"imageOffset":189258,"symbol":"ReceiveNextEventCommon","symbolLocation":594,"imageIndex":8},{"imageOffset":188645,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":70,"imageIndex":8},{"imageOffset":257901,"symbol":"_DPSNextEvent","symbolLocation":927,"imageIndex":9},{"imageOffset":251434,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1394,"imageIndex":9},{"imageOffset":195801,"symbol":"-[NSApplication run]","symbolLocation":586,"imageIndex":9},{"imageOffset":230867,"imageIndex":6},{"imageOffset":2038399,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":431,"imageIndex":4},{"imageOffset":2056194,"symbol":"QCoreApplication::exec()","symbolLocation":130,"imageIndex":4},{"imageOffset":168255,"symbol":"qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*)","symbolLocation":1535,"imageIndex":10},{"imageOffset":1571005,"imageIndex":2},{"imageOffset":898514,"imageIndex":2},{"imageOffset":782676,"imageIndex":2},{"imageOffset":79689855211858,"imageIndex":3},{"imageOffset":320862,"imageIndex":2},{"imageOffset":329505,"imageIndex":2},{"imageOffset":1468329,"imageIndex":2},{"imageOffset":1484848,"symbol":"QScriptEngine::evaluate(QString const&, QString const&, int)","symbolLocation":352,"imageIndex":2},{"imageOffset":236648,"symbol":"RScriptHandlerEcma::eval(QString const&, QString const&)","symbolLocation":40,"imageIndex":1},{"imageOffset":233949,"symbol":"RScriptHandlerEcma::doScript(QString const&, QStringList const&)","symbolLocation":589,"imageIndex":1},{"imageOffset":1055217,"symbol":"RScriptHandler::autostart(QString const&, QStringList const&)","symbolLocation":1857,"imageIndex":0},{"imageOffset":51726,"symbol":"main","symbolLocation":5070,"imageIndex":11},{"imageOffset":21806,"symbol":"start","symbolLocation":462,"imageIndex":12}]},{"id":1471139,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":40266,"symbol":"__select","symbolLocation":10,"imageIndex":13},{"imageOffset":685657,"symbol":"__CFSocketManager","symbolLocation":641,"imageIndex":7},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":14},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":1471148,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6506,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":13},{"imageOffset":7384,"symbol":"mach_msg","symbolLocation":56,"imageIndex":13},{"imageOffset":525133,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":7},{"imageOffset":518616,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":7},{"imageOffset":515612,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":7},{"imageOffset":1755534,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":9},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":14},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":1473888,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":14}]},{"id":1474569,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":14}]},{"id":1474663,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":14}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4536983552,
"size" : 4444160,
"uuid" : "630ebce2-f5d2-3bde-a31a-c53bc1ac8dfb",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/Frameworks\/libqcadcore.dylib",
"name" : "libqcadcore.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4550750208,
"size" : 19161088,
"uuid" : "a792a831-43c6-3dfa-bca6-c6b86456ec4c",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/Frameworks\/libqcadecmaapi.dylib",
"name" : "libqcadecmaapi.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4591439872,
"CFBundleShortVersionString" : "5.14",
"CFBundleIdentifier" : "org.qt-project.QtScript",
"size" : 1818624,
"uuid" : "b2ce3701-570d-3a85-bba2-cff6b6ef2ad7",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/Frameworks\/QtScript.framework\/Versions\/5\/QtScript",
"name" : "QtScript",
"CFBundleVersion" : "5.14.2"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 4600086528,
"CFBundleIdentifier" : "org.qt-project.QtCore",
"size" : 5632000,
"uuid" : "435c4ad2-bf9e-3561-93eb-041e7dab5fca",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/Frameworks\/QtCore.framework\/Versions\/5\/QtCore",
"name" : "QtCore",
"source" : "P",
"arch" : "x86_64",
"base" : 4579151872,
"CFBundleIdentifier" : "org.qt-project.QtWidgets",
"size" : 4476928,
"uuid" : "b4e7a5b5-9c2f-37fe-9b65-7ede8a80eea0",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/Frameworks\/QtWidgets.framework\/Versions\/5\/QtWidgets",
"name" : "QtWidgets",
"source" : "P",
"arch" : "x86_64",
"base" : 4593594368,
"size" : 1495040,
"uuid" : "0c163cef-1f43-3921-b089-07b7ee848d67",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/PlugIns\/platforms\/libqcocoa.dylib",
"name" : "libqcocoa.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703593951232,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5255168,
"uuid" : "70b99b27-1b5b-33c4-b401-2ecdb80f3303",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1866"
"source" : "P",
"arch" : "x86_64",
"base" : 140703741800448,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3096576,
"uuid" : "06fdecd6-9f69-397b-b1e2-a8226c0ba7ed",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "x86_64",
"base" : 140703638491136,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15269888,
"uuid" : "1a1a9da7-da66-31da-92cd-51b9cf968145",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2113.60.148"
"source" : "P",
"arch" : "x86_64",
"base" : 4686192640,
"size" : 2134016,
"uuid" : "4bc5f9ad-fd59-3fc6-8b8e-54970b4d090b",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/PlugIns\/script\/libqtscript_core.dylib",
"name" : "libqtscript_core.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4525047808,
"CFBundleShortVersionString" : "3.28",
"CFBundleIdentifier" : "org.qcad",
"size" : 65536,
"uuid" : "26e81ca6-4593-3769-b6b7-8a9bb876a886",
"path" : "\/Applications\/QCADCAM-Trial.app\/Contents\/MacOS\/QCADCAM-Trial",
"name" : "QCADCAM-Trial",
"CFBundleVersion" : "3.28.1"
"source" : "P",
"arch" : "x86_64",
"base" : 4526370816,
"size" : 442368,
"uuid" : "2517e9fe-884a-3855-8532-92bffba3f81c",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593406464,
"size" : 229376,
"uuid" : "d0b338e0-26be-371b-a819-80b7d619a4ad",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593635840,
"size" : 49152,
"uuid" : "e5d44afd-2577-3cee-8711-9d8d426229e0",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"sharedCache" : {
"base" : 140703590379520,
"size" : 19331678208,
"uuid" : "62c3e042-43ff-3ed0-b185-f12338b5fb88"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=2.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.7G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 896K 7 \nActivity Tracing 256K 1 \nCG backing stores 5408K 8 \nCG image 272K 22 \nColorSync 228K 27 \nCoreAnimation 172K 12 \nCoreGraphics 16K 3 \nCoreUI image data 2588K 20 \nFoundation 16K 1 \nJS JIT generated code 128.0M 1 \nJS JIT generated code (reserved) 1.9G 1 reserved VM address space (unallocated)\nJS VM Gigacage 20.0M 80 \nJS VM Isolated Heap 16.2M 4 \nKernel Alloc Once 8K 1 \nMALLOC 273.2M 104 \nMALLOC guard page 32K 8 \nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nObjC additional data 15K 1 \nSTACK GUARD 56.0M 6 \nStack 10.5M 6 \nVM_ALLOCATE 172K 26 \nWebKit Malloc 40.8M 55 \n__CTF 756 1 \n__DATA 22.7M 414 \n__DATA_CONST 15.7M 204 \n__DATA_DIRTY 753K 115 \n__FONT_DATA 4K 1 \n__LINKEDIT 663.6M 63 \n__TEXT 342.3M 424 \n__UNICODE 592K 1 \ndyld private memory 1056K 3 \nmapped file 449.7M 40 \nshared memory 804K 23 \n=========== ======= ======= \nTOTAL 4.3G 1684 \nTOTAL, minus reserved VM space 2.0G 1684 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5ffde50ce2aacd000d47a95f",
"factorPackIds" : {
"deploymentId" : 240000311
"rolloutId" : "63582c5f8a53461413999550",
"factorPackIds" : {
"deploymentId" : 240000002
"experiments" : [
"treatmentId" : "6dd670af-0633-45e4-ae5f-122ae4df02be",
"experimentId" : "64406ba83deb637ac8a04419",
"deploymentId" : 900000017
Model: MacBookPro13,3, BootROM 512.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2.7 GHz, 16 GB, SMC 2.38f12
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 455, AMD Radeon Pro 455, PCIe, 2 GB
Display: Color LCD, 2880 x 1800 Retina, Main, MirrorOff, Online
Display: U28E590, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), MirrorOff, Online
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1710.4)
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB3.0 Hub
USB Device: USB30Bus
USB Device: USB2.0 Hub
USB Device: USB-C Digital AV Multiport Adapter
USB Device: Apple T1 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 41.5
Re: Crashed on undo
Post by CVH » Mon Aug 21, 2023 2:48 am
SQLGuy,
This is or for the QCAD Pro forum or for the QCAD/CAM forum.
There is no CE version of QCAD/CAM only a trial version.
And QCAD/CAM is QCAD Pro + CAM
Remark the endless text you posted ... It is better to set that in a code panel.
Select the text in your post and hit the </> button above the text box.
One can edit the posted topic.
Here I find 3 shortcuts for Undo, one is especially for Mac:
https://www.ribbonsoft.com/archives/sho ... uts_en.pdf
Nothing in the crash report tells me what action you were undoing.
Have you any idea? ... Can you replicate it?
