Crashing when editing custom color
massimo
Post by massimo » Mon Oct 23, 2023 10:36 am
Hi, I have layers with custom colors.
When editing such a layer, opening the custom color again for copying the color code in order to create a new layer of the same color, QCad is always crashing:
(process:19053): Gtk-CRITICAL **: 11:33:23.668: _gtk_css_lookup_resolve: assertion '(((__extension__ ({ GTypeInstance *__inst = (GTypeInstance*) ((provider)); GType __t = ((_gtk_style_provider_private_get_type ())); gboolean __r; if (!__inst) __r = (0); else if (__inst->g_class && __inst->g_class->g_type == __t) __r = (!(0)); else __r = g_type_check_instance_is_a (__inst, __t); __r; }))))' failed
(process:19053): GLib-GObject-CRITICAL **: 11:33:23.668: g_object_set_data_full: assertion 'G_IS_OBJECT (object)' failed
(process:19053): Gtk-ERROR **: 11:33:23.668: Can't create a GtkStyleContext without a display connection
Trace/breakpoint trap
It's a custom build:
Version:
3.28.2.0 (3.28.2)
Internet:
QCAD.org
Erstellungsdatum:
Sep 15 2023
Revision:
Qt Version:
5.15.10
Architektur:
x86_64
Compiler:
gcc 12.3.1
Feature-Request: Please add an option for layers to duplicate.
Community Version 3.28.2.0, Gentoo Linux on amd64
Re: Crashing when editing custom color
Post by CVH » Mon Oct 23, 2023 2:54 pm
I wonder if one would get support for custom compiled CE installations ... :wink:
Requests inserted in various topics and replies will hardly be noticed.
The best place to file feature requests is on QCAD Bugtracker:
https://qcad.org/bugtracker/
Duplication of a layer is a QCAD pro feature.
QCAD
