Import Error
vestro
Import Error
Post by vestro » Wed Jul 08, 2015 5:01 am
Hi, this is vestro from China.
I have a problem to open a *.dxf file. I drawed some polygons in QCAD, then I saved as new.dxf, when I try to open new.dxf, it shows me a cation:
[Import Error]
[Cannot open file 'C:\Documents and Settings\Administrator\桌面(this chinese means DESKTOP)\new.dxf'.]
[ Please check your access rights, the file format and file extension.]
I tried many times of "create new file -- draw -- save -- open", even reboot the system, but the problem still not solved.
Can U help me, please
Thank you :lol:
我前往你的城市,走过你来时的路。
vestro
Re: Import Error
Post by vestro » Wed Jul 08, 2015 5:02 am
Sorry, here is my version info:
Versions
QCAD version: 3.9.3.0
Date: May 12 2015
Qt version: 4.7.4
Compiler version: MSVC++ 10.0 (2010)
OS: Windows
OS version: Windows XP (operating system version 5.1)
Locale
QCAD locale: zh_CN
Country: 44
Language: 25
Script: -1
Script name: No information available (Qt < 4.8)
Decimal point: 46
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: System
我前往你的城市,走过你来时的路。
Re: Import Error
Post by Husky » Wed Jul 08, 2015 9:37 am
Hello vestro - welcome to the QCAD Forum.
Have you tried to save this new.dxf drawing to another locations on your PC? You have the access rights for those locations? Same problem?
Could you please post this particular drawing to the forum?
Thanks!
vestro
Re: Import Error
Post by vestro » Thu Jul 09, 2015 2:37 am
Thank you for your suggestion! It help me solved the problem.
I thik the problem is caused by directory's name. I moved new.dxf to D:\, it can be opened properly. So I drawed some new drawing for test, and try to save them to some different directories, I realized that QCAD can't open files(include dxf, jpg, png and so on) form directories that containts CHINESE.
It that a bug?
Thank you 8)
我前往你的城市,走过你来时的路。
Re: Import Error
Post by andrew » Mon Jul 13, 2015 8:16 am
Yes, that's a known limitation of dxflib used in the free QCAD Community Edition.
