closing drawing, save the changes
ben7v
Post by ben7v » Fri Aug 14, 2015 3:11 am
Good Evening,
I have recently installed the latest build of QCad 3.9.8.0 and every time I close any drawings, the message about saving the changes before closing the drawing pops up. Is it an installation problem or an application preferences that I need to adjust?
The weird problem is that it only happens when I am using QCad on Ubuntu and not on Win 7. I installed the current QCad build on both OS and the Win 7 version doesnt have the message when compared to the Ubuntu version. Other than this small problem, everything else works great.
My current setup is a Lenovo Thinkpad running a dual boot system, Windows 7 and Ubuntu 14.04LTS. The OS's are 64 bit with all the updates installed.
Thanks for any help
Re: closing drawing, save the changes
Post by andrew » Fri Aug 14, 2015 10:10 am
Is this QCAD Professional or the QCAD Community Edition? Thanks.
ben7v
Post by ben7v » Fri Aug 14, 2015 1:14 pm
sorry, I forgot to include that its the community edition.
Post by andrew » Fri Aug 14, 2015 1:22 pm
No problem. I've moved this topic to the appropriate forum.
riverbuoy
Senior Member
Post by riverbuoy » Sun Aug 16, 2015 10:32 pm
I've had exactly the same problem, under Linux, since about version 3.7.3 (Community version). Yesterday I made a discovery. I decided to install the Pro Trial version in Windows 8.1, and remove the pro libraries, so as to have the Community version installed. When I had removed the libraries, the exact same problem appears in the Windows version. So, I put back the proscripts library, and the problem disappeared.
It would appear that something was removed from the community version and put in the pro scripts library.
@Andrew - Should I enter a bug report or is this a fairly easy fix?
riverbuoy
Post by andrew » Mon Aug 17, 2015 10:05 am
This is a known problem with QCAD CE, yes. Feel free to report a bug and assign to "QCAD Community", thanks.
