Question about building qcad on linux
johnrcox46
Post by johnrcox46 » Wed Oct 07, 2015 4:02 am
I am trying to build qcad-3.10.0.0 on a gentoo linux system.
I am able to create the qcad-3.10.0.0 system and unpack the source code into the file.
qmake works.
make works.
when I try to run qcad, the closest I can come to qcad is in release/qcad-bin. When I try to run it, the following happens:
  • bopper release # ./qcad-bin
    ./qcad-bin: error while loading shared libraries: libqcadecmaapi.so: cannot open shared object file: No such file or directory
    bopper release #
I tried a make intsall, which appeared to succeed, but I don't know where there is an executalble.
I don't know how to proceed. Any thoughts?
riverbuoy
Senior Member
Re: Question about building qcad on linux
Post by riverbuoy » Thu Oct 08, 2015 4:07 am
Hi johncrox46
You need to tell QCAD where to find the libraries. They are in the same directory as QCAD.
So to launch QCAD:
cd release
LD_LIBRARY_PATH=. ./qcad-bin
(Note the space between the two dots)
Hope this explains it.
riverbuoy
