Round Arc
Posted: Tue Feb 09, 2016 8:07 pm
by benDragon81037
Hey there.
I have another problem, how do you round an arc intersecting an elipse? I kinda need to make a transition curve between the elipse and the arc here shown by the blue entities:
Re: Round Arc
Posted: Tue Feb 09, 2016 9:47 pm
the easiest way would be:
select the ellipse,
"Explode" the ellipse what will change it to a polyline,
launch the Modify -> Round tool to make the transition.
Note: Exploding the eclipse could lead to a slightly different ellipse / Polyline shape depending on your "Application preferences / Modify / Explode" settings .
Re: Round Arc
Posted: Tue Feb 09, 2016 10:53 pm
by benDragon81037
Thanks for the quick reply.
I tried to explode the elipse, as shown here:
Unfortunately, it says "The two entities cannot be rounded."
Re: Round Arc
Posted: Tue Feb 09, 2016 11:17 pm
benDragon81037 wrote:Unfortunately, it says "The two entities cannot be rounded."
That sounds like the chosen radius wasn't working (to big / to small?).
Could you attach this dxf to your post?
Re: Round Arc
Posted: Tue Feb 09, 2016 11:29 pm
by benDragon81037
Hey there.
Alright, but it will look a little busy with all of the construction lines (stitches / guides) that I've placed to create an accurate blueprint.
Re: Round Arc
Posted: Wed Feb 10, 2016 12:59 am
Thanks for the example drawing!
Ok, your drawing unit is Meter,
To make that transition I made the "Overlay 2" Layer active,
worked on Top projection / left side
started the round tool,
chose a radius of 0.2,
clicked both lines and it was working as expected.
Note: Top projection right side / ellipse isn't exploded.
Re: Round Arc
Posted: Wed Feb 10, 2016 1:35 am
by benDragon81037
Yeah, I exploded only one corner to test if it worked, unfortunately, I keep getting the "The two entities cannot be rounded". Error message, which I keep on getting.
Re: Round Arc
Posted: Wed Feb 10, 2016 1:54 am
benDragon81037 wrote:Yeah, I exploded only one corner to test if it worked...
That is what I thought.
benDragon81037 wrote:... unfortunately, I keep getting the "The two entities cannot be rounded". Error message, which I keep on getting.
Ok, then I have additional questions ...
Question 1:
What is your radius size?
Question 2
You are using the radius value with a dot or a comma? If yes try to use a dot instead of a comma and/or vice versa.
Re: Round Arc
Posted: Wed Feb 10, 2016 9:57 am
by Clive
Hi benDragon81037
Something like this ?
Arc Fit 1.jpg (40.83 KiB) Viewed 4848 times
Arc Fit 2.jpg (50.82 KiB) Viewed 4848 times
Re: Round Arc
Posted: Wed Feb 10, 2016 1:45 pm
by benDragon81037
Yeah, something like that.
The radius size is 0.2 (I tried 0,2, but it ended up making the radius 2 which is too big, it also was 0.15 / 0,15), both the 0.2 and 0,2 ended up with the same result though.
Re: Round Arc
Posted: Thu Feb 11, 2016 9:44 pm
by benDragon81037
Say, my blueprint's nearly finished, the last problem I'd like to solve would be this single problem, but I'd really like an answer to my delima.
Re: Round Arc
Posted: Fri Feb 12, 2016 3:16 pm
by Clive
Hi benDragon81037
See attached your drawing, which I have edited to suit your request for 'rounding' off. I've saved it as R15 DXF, so you should be able to open this with the Community Version.
Class 81 8 Revision 1CT.dxf
(337.76 KiB) Downloaded 162 times
Rev 1CT.jpg (85.68 KiB) Viewed 4804 times
Rev 1CT2.jpg (23.03 KiB) Viewed 4804 times
Rev 1CT3.jpg (25.03 KiB) Viewed 4804 times
All you need to do is select the yellow entities and change layer/Colour.
Regards
Re: Round Arc
Posted: Fri Feb 12, 2016 3:39 pm
by benDragon81037
Thank you for posting the fixed version, and yes, it does solve that problem and only that problem (by getting you to do it for me), but I don't think that doing stuff for me is good for me in the long term when I may need to do this again.
Re: Round Arc
Posted: Fri Feb 12, 2016 4:13 pm
by Clive
Sure I understand and glad to hear it.
The number One thing to do is trial the Pro version, the modify tools are quite something, the best I've seen in a 2D CAD program.
You stated initially that you wanted to 'round' off, so my way forward was to use a Spline to do the job:
1. Set up new layer - 'Construction'.
2. On this layer work out and place points for reference.
3.Using the Spline tool, draw a Spline (with controlled points) between my construction points.
4. Use the modify tools, break out segment and Divide I cleaned up the drawing.
Hope this helps.
Re: Round Arc
Posted: Fri Feb 12, 2016 10:35 pm
by benDragon81037
Do you think you could put illustrations?
