Offset on full ellipses
marzof
Post by marzof » Fri Feb 26, 2016 4:10 pm
I noticed that the offset tools on full ellipses is not working on open source version (after disabling pro plugins) of QCAD 3.12.8. I noticed the issue using Linux (Ubuntu) and Windows 7.
The issue doesn't show up on trimmed ellipses.
I think it's related to the ShapeAlgorithms.getOffsetEllipses() function and, notably, it's seems related to the nature of the new entity (being a polyline or a spline).
It seems to me that the lines
if (isFullEllipseShape(shape)) {
   spl.setPeriodic(true);
are the reason of this unexpected behavior since setPeriodic is not a method of polylines.
Am I right?
Re: Offset on full ellipses
Post by andrew » Mon Mar 07, 2016 9:08 am
Moved to QCAD Community Edition forum.
marzof
Post by marzof » Fri Mar 18, 2016 6:44 pm
in order to solve the bug I made a little change in ShapeAlgorithms.js (scripts folder).
In ShapeAlgorithms.getOffsetEllipses function I replaced the lines
whit these lines:
                if (isSplineShape(spl)) {
                else {         // is Polyline
                    spl.setClosed(true);
I hope it helps.
Bye
Post by andrew » Mon Mar 21, 2016 9:33 am
Thanks. The fix has been applied.
Bug report:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1399
