Save or discard unaltered new sketch?
mwrsa
Post by mwrsa » Wed Mar 23, 2016 9:55 pm
QCAD community 3.12.8.0 32bit and 64bit
Linux Mint 17.3 32bit and 64bit
Hey forum!
I hope you guys can help me, I already searched a little but probably could not come up with the right words...
When you open QCAD you are presented a new sketch. In case you just want to close that you always have to confirm (save/discard), same issue if I opened a sketch just to view then close it again. I did not draw / delete/ alter it in any way.
Is there any way to only get that prompt if you actually altered a sketch? Or is it the "last accessed" date that changes by these actions?
Thank you. mwrsa
EDIT: Am I not being clear in my description of the issue, or does no solution exist? Many views but no response makes me wonder...
riverbuoy
Senior Member
Re: Save or discard unaltered new sketch?
Post by riverbuoy » Thu Apr 07, 2016 2:09 pm
Hi mwrsa,
mwrsa wrote:When you open QCAD you are presented a new sketch. In case you just want to close that you always have to confirm (save/discard), same issue if I opened a sketch just to view then close it again. I did not draw / delete/ alter it in any way.
This is a known problem with the community version. It used to work a long time ago, but for now, nobody has a solution.
Sorry I can't be more helpful.
riverbuoy
mwrsa
Post by mwrsa » Tue Apr 12, 2016 9:45 am
Well thank you, you have been helpful in clearing that up!
Too bad that my programming skills are not up to par to just correct that, it doesn't sound like a great deal of work to me.
Well, until it gets fixed I will have to live with it. Not that I could not afford the commercial edition, but I just do not need these extras it comes with. And just for that bug - hm, no.
Once more thank you, cheers, mwrsa
