[solved] Error loading library
bmormede
Post by bmormede » Sun Aug 28, 2016 5:11 pm
Hi every one,
I'm using on laptop Linux Mageia 5 64bits and QCAD community version 3.
QCAD is running fine except that I can't load the library. If I configure the path for library, when opening QCAD instance I get the following message:
Plugin LibraryBrowser: cannot connect to DB.
Driver error: Driver not loaded
Database error: Driver not loaded
Database file:
Library browser will not be available
I install also QCAD on my desktop Linux Mageia 32bits and QCAD community version 3. I have the same problem.
Is it a limitation of the community edition or a configuration problem ?
Thank you in advance for your help.
B. Mormede
Moderator
Re: Error loading library
Post by Clive » Mon Aug 29, 2016 10:27 am
Hello bmormede and welcome here to the QCAD forum :)
The library browser should work fine in the community edition, could it be that you need to set permissions?
bmormede
Post by bmormede » Thu Sep 01, 2016 11:45 am
Thank you Clive pour your answer.
I thought also it could be a problem of permission to access the related forders.
The qcad folder is located /usr/share/qcad
and the libraries, plugins, etc in this folder.
I set permissions of qcad folder to 777 to try again
The conf file is located in ~/.config/QCAD/qcad3.conf
With permissions set to 777 -R to qcad folder, it still doesn't work.
BM
Post by andrew » Thu Sep 01, 2016 2:09 pm
The error indicates the the data base driver could not be loaded. That's the file plugins/sqldrivers/libqsqlite.so in your QCAD installation directory. This file should be made executable and readable by all.
bmormede
Post by bmormede » Wed Sep 07, 2016 8:36 pm
Hi Andrew,
Thx for your reply.
The folder plugins/sqldrivers was empty. I guess there was a problem with the qcad.rpm package from Mageia dist.
I reinstall Qcad from the source code and it's fine and working well.
Thx a lot for your help.
Bernard
