Regarding Hatching.
Rabindra
Regarding Hatching.
Post by Rabindra » Thu Oct 06, 2016 7:18 am
Sir,
Here i attached file with this mail.
When i am going to do hatching after importing dxf format from freecad.
I found in command line as Loop not closed at point -176/-51.2.
can you suggest how would i get hatch after importing dxf file into qcad?
Actually i tried to do exploding the geometry file and select one one segment of line to make it closed contour.
It takes a lot time to do hatch. Is there any way to get hatch with out exploding the geometry?
Please let me know how would i fix this type problem?
Hatching.dxf
(1.99 MiB) Downloaded 138 times
Re: Regarding Hatching.
Post by andrew » Thu Oct 06, 2016 7:41 am
Please let us know which part of the drawing in which block you are trying to fill with a hatch so we can help you most efficiently, thanks.
Rabindra
Post by Rabindra » Thu Oct 06, 2016 8:02 am
Hello sir,
I need to do sectional view for the model.
So when i open the exported file in qcad it is coming as single block as i sent before the attachment.
Now i am sending the hatched document so that if you found any solution for the same.
I attached here two dxf files 6.1 & 6.2. dxf files.
In 6.1dxf i select the sketch and do hatching. here it is doing well.
When i open 6.2.dxf then i selcet hatch option, but it could't . so that i simply exploded and than make hatching.
Is there any way to do the hatch as i previously send the attachment as hatch.dxf.
6.2.dxf.tar.gz
(683.42 KiB) Downloaded 126 times
6.1.dxf.tar.gz
(1000.17 KiB) Downloaded 130 times
Rabindra
Post by Rabindra » Thu Oct 06, 2016 8:06 am
Sir,
Pls find the hatch Png. here with this mail
Rabindra
Post by Rabindra » Thu Oct 06, 2016 8:12 am
Sir,
How to reduce the size of the dxf file ?
Post by Husky » Thu Oct 06, 2016 4:53 pm
Hello Rabindra,
Rabindra wrote:Actually i tried to do exploding the geometry file and select one one segment of line to make it closed contour.
Have you ever tried to use the Select tool "(De-)Select Contour"? Use also the option "Add to the current selection" for all hatches which belongs together. That would be a time saver and your hatch is proper organized :wink:
Rabindra wrote:Is there any way to get hatch with out exploding the geometry?
You could do the hatching directly in the Block (Edit content of the selected block) - but the drawings are not really well organized. However - I would always use an extra layer for the hatching in cases like this one.
Post by Husky » Thu Oct 06, 2016 7:54 pm
Here is an example based on your submitted drawing:
Note: If the drawing isn't precisely drawn you will be confronted by gaps and overlapping entities. If that so you have to fix that first!
Rabindra
Post by Rabindra » Fri Oct 07, 2016 6:11 am
Sir,
Thank you very much.
