Compile Visual Studio 2010
lala
Post by lala » Tue Nov 29, 2016 12:12 pm
Hello~
Help me ㅠㅠ
Install : QT5.1.1 , QT Add In 1.2.5, VS 2010( Professional ) , O.S: Windows7 64bit
step 1)
I downed the QCAD Source Code in the http://qcad.org/en/qcad-cam-downloads-trial
step 2)
I unzip the qcad-3.15.5.0.zip
step 3)
in QT Command(32bit) line, switch to the qcad-3.15.5.0 folder and qmake -r -spec win32-msvc2010 -tp vc
Error Message : Project MESSAGE: Copying imageformats\ggif.dll
step 4)
I Compiled the qcad-3.15.5.0\src\src.pro in the Visual Studio 2010
step 5)
ERROR Message: don't find the qcad-3.1.5\src\src.sln (Please check attached file)
Re: Compile Visual Studio 2010
Post by andrew » Tue Nov 29, 2016 1:06 pm
Please do not post the same question multiple times, thanks.
I've deleted your duplicate topic "I Compiled the qcad-3.15.5.0\src\src.pro in the QT5 of the Visual Studio 2010".
You can find detailed compilation instructions (using qmake / nmake) on our web site at:
http://qcad.org/en/component/content/ar ... om-sources
Compiled and fully working packages are available from:
http://www.qcad.org/en/qcad-downloads-trial
lala
Post by lala » Tue Nov 29, 2016 1:20 pm
Sorry.
I tried the manual ( http://qcad.org/en/component/content/ar ... om-sources )
But I Can't do it.
Which Step is wrong with my question?
lala
Post by lala » Tue Nov 29, 2016 1:45 pm
andrew wrote:Please do not post the same question multiple times, thanks.
I can't linux.
lala
Post by lala » Tue Nov 29, 2016 1:48 pm
I can't linux.
I can only use windows or windows QT.
I can't linux.
