I'm going to package QCad for Fedora using the code provided by your GitHub project. However, i'm still not sure if that code provides or doesn't provide proprietary code:
If it does, where is proprietary code ? And, can i remove it without compromising QCad functions?QCAD - The Open Source 2D CAD. QCAD is a crossplatform CAD solution for Windows, Mac OS X and Linux. It supports the DXF format and optionally the DWG format (through a proprietary plugin). http://www.qcad.org
Thanks.
