Circle Intersecting Ellipse
alex_holden
Post by alex_holden » Wed Dec 07, 2016 11:03 am
I'm having a problem where QCAD doesn't seem to be able to find the intersections between a circle and an ellipse. See the attached sample file.
The larger circle behaves as I would expect; the smaller circle behaves as if it didn't intersect the ellipse. For example if you try to break out the segment of the smaller circle that is inside the ellipse, the whole circle is deleted.
circle_intersecting_ellipse_test.dxf
(20.98 KiB) Downloaded 125 times
alex_holden
Re: Circle Intersecting Ellipse
Post by alex_holden » Wed Dec 07, 2016 11:08 am
P.S. I'm using the latest free Mac QCAD.
J-J
Moderator
Post by J-J » Wed Dec 07, 2016 6:50 pm
strange indeed e_confused
I tried only moving the ellipse by 1 unit, and then it worked as expected....more e_confused
JJ
Post by andrew » Thu Dec 08, 2016 8:04 pm
alex_holden
Post by alex_holden » Fri Dec 09, 2016 8:11 am
Thanks Andrew!
