I cannot open dxf files created with QCAD
pdubalen
Post by pdubalen » Sun Dec 18, 2016 2:09 pm
Good morning,
I just installed the QCAD new version 3.16.1 (for windows).
I cannot open dxf files I created a few months ago, as soon as the QCAD pro add-on has expired it seems.
I always used the free version.
Thank you and kind regards.
Re: I cannot open dxf files created with QCAD
Post by Husky » Sun Dec 18, 2016 6:13 pm
Good morning pdubalen - welcome to the forum.
pdubalen wrote:Good morning,
Could you please attache one of those drawing for testing? Thanks.
pdubalen
Post by pdubalen » Thu Jan 12, 2017 9:57 am
Thank you for your answer.
I'm sorry, I used a wrong forum and I thought my post was lost.
Here is an example.
Regards.
Mecanismes Chappe.dxf
(270.1 KiB) Downloaded 84 times
Post by andrew » Thu Jan 12, 2017 10:03 am
Please remove the trial add-ons if you wish to use the free version. If you cannot remove the add-ons automatically (using the remove button in the trial widget), you need to delete the indicated files manually.
pdubalen
Post by pdubalen » Thu Jan 12, 2017 11:48 am
Thank you but I did.
I just installed the new 3.16.4 and I removed the pro version trial. I had to use "run as admin" for that.
I still have the issue: "impossible to open the file, import failed"
In french in my version I tried to translate.
Regards.
Post by andrew » Thu Jan 12, 2017 11:57 am
pdubalen wrote:"impossible to open the file, import failed". In french in my version I tried to translate.
Could it be that the file is in a path that contains international characters (French accents, etc)? If so, can you move the file to the desktop or a path that does not contain any unicode characters? The QCAD Community Edition uses dxflib which cannot handle unicode paths under Windows.
pdubalen
Post by pdubalen » Thu Jan 12, 2017 12:00 pm
Thank you, that's right.
The complete path contains indeed french accents.
I changed that and now it works.
Thank you again.
