QCAD 3 on Fedora
sagitter
QCAD 3 on Fedora
Post by sagitter » Fri Dec 23, 2016 1:02 pm
Hi all.
QCAD 3.16.2 is now officially packed for Fedora Project on Fedora>=24.
Homepage of the RPMs: https://admin.fedoraproject.org/pkgdb/p ... rpms/qcad/
Homepage on Fedora Apps: https://apps.fedoraproject.org/packages/qcad
if you use Fedora as main S.O. and bump into a packaging bug, please open a bug report on bugzilla.redhat.com or into this forum.
QCAD is available for testing for next 8 days, then pushed into stable repositories if everything works.
Regards.
Re: QCAD 3 on Fedora
Post by andrew » Fri Dec 23, 2016 1:06 pm
Thanks sagitter!
Just a footmark: This is the free QCAD Community Edition. If you are using QCAD Professional, please download always from your personal download link sent to you by e-mail.
sagitter
Post by sagitter » Fri Dec 23, 2016 2:24 pm
QCAD Professional is not released with open code; i can pack QCAD Community Edition only.
Post by andrew » Fri Dec 23, 2016 2:26 pm
sagitter wrote:QCAD Professional is not released with open code; i can pack QCAD Community Edition only.
Yes exactly. That's what I tried to tell the interested users here :wink:
sagitter
Post by sagitter » Fri Dec 23, 2016 2:33 pm
This forum is for QCAD professional e_surprised
I realized just now.
Post by andrew » Fri Dec 23, 2016 2:54 pm
No worries, I've moved it to the QCAD Community Edition forum, leaving a shadow topic in place.
