Is there a feature to properly draw lead arrows between descriptive text and parts of a drawing?
For example, what is the correct way to do what I have done here in this example?:
.dxf file attached.
Lead arrows for text in drawings. (solved)
- Blade fixing.dxf
- (36.93 KiB) Downloaded 475 times
Re: Lead arrows for text in drawings.
You can use the "Leader" tool which is part of the Dimension set:
Got it, thanks Husky.
