Some layers can not be shown anymore
Pancho
Post by Pancho » Mon May 22, 2017 2:07 pm
Operating system: Win7pro
I was working on QCAD3.12 and everything worked well.
I have just updated to QCAD3.17, the latest version, and now I can not see anymore the other layers of the design...
Even old design files (not modified by QCAD3.17) have the same problem...
I attache an old design file and only the viewable layers saved are still visible...
Can someone help me?
Thanks a lot!
Pancho
BaseGimball.dxf
(1.28 MiB) Downloaded 373 times
Re: Some layers can not be shown anymore
Post by andrew » Mon May 22, 2017 2:11 pm
Please enable (check) Edit > Application Preferences > Widgets > Layer List > Show frozen column
You can then show and thaw all layers if desired:
Layer > Show all layers
Layer > Thaw all layers
Some of your layers may be frozen or hidden or both.
Pancho
Post by Pancho » Mon May 22, 2017 2:21 pm
Thanks Andrew for your answer.
in 'Edit > Application Preferences > Widgets > Layer List' I only have 'Enable alternating row colors'.
I can see in the layer list the icons 'visible' and 'lock'. And even if I click on 'Show All Layers', only the layers that were visible during the last save, contains something. All other layers looks to be empty...
Post by andrew » Mon May 22, 2017 2:26 pm
Are you using QCAD Professional or the free QCAD Community Edition?
Pancho
Post by Pancho » Mon May 22, 2017 2:28 pm
I have installed QCad professionnal and remove the professionnal plug-ins (as asked at the first run).
So I'm running the free QCAD Community Edition.
Post by andrew » Mon May 22, 2017 2:29 pm
OK, I'll move this to the community forum.
Pancho
Post by Pancho » Mon May 22, 2017 2:45 pm
I have installed in an other folder the version 3.12.6 and I can see the drawings of all layers with this version.
Why can I not see them with version 3.17?
So, I continue with 3.12.6 for the moment.
Thanks for your help.
