"No export filters have been found. Aborting..."
keenanspringer96
Post by keenanspringer96 » Wed Dec 27, 2017 6:56 pm
Has anyone seen this error before? just downloaded QCAD onto my Lenova ideapad 110. i did the 64-bit version.
When i go to click "Save As", it doesn't pop up the normal window you would use to navigate to a save location. it just pops up this error in the command line at the bottom. "Export Files Not Found, Aborting..."
Any help would be appreciated.
Re: "No export filters have been found. Aborting..."
Post by Husky » Thu Dec 28, 2017 1:47 am
Please provide more information like Operating system, QCAD version (Version number, Trial, CE or Pro), used installation packet (msi, zip etc). Thank you.
Post by andrew » Thu Dec 28, 2017 1:23 pm
The error you are likely referring to is "No export filters have been found. Aborting..."
This indicates that you have deleted all plugins and you now have no import or export functionality left in your QCAD installation..
What you probably wanted to do was removing the QCAD Professional trial plugins only.
keenanspringer96
Post by keenanspringer96 » Thu Dec 28, 2017 5:42 pm
I will try to uninstall and re-download the program. Thank you.
