[FeatureRequest] Rotate the view
massimo
Post by massimo » Fri Dec 29, 2017 1:27 pm
I would appreciate the possibility to rotate the view for working in a different angle on the same drawing.
For instance I'm adding a lot of text to circuit layout plans, often in upright position , would be easier to edit in 90° rotated instead of inclining the head all the time.
This could be also useful for any mechanical engineering, just to view it from a rotated point of view.
git build current origin/master, Gentoo Linux on amd64
