[FeatureRequest] Include shared blocks and layers
Support shared blocks and layers
Useful.
3
100%
I don't need that.
0
No votes
I don't know.
0
No votes
Total votes: 3
massimo
Post by massimo » Mon Jan 29, 2018 12:02 pm
is there any way or plan to support shared blocks and layers and including that in the drawings?
I start one drawing with most blocks and layers, later I copy lot of blocks into new drawings. Later it is very difficult to have all used blocks and layers synchronized over the drawings. Even copying a changed block from one drawing into some other drawing that already had a version of that block makes the old block appear instead. So it is always required to remove the old block first before copying. That means loosing all instances of that block.
The only solution currently is, to have all drawings in one single file, which is worse. For printing it would be required to switch the print area around.
Community Version 3.24.3.0 (3.24.3), Gentoo Linux on amd64
Re: [FeatureRequest] Include shared blocks and layers
Post by andrew » Mon Jan 29, 2018 12:09 pm
For blocks, that's called an XRef and yes, support for XRefs is planned (QCAD Pro):
http://www.qcad.org/bugtracker/index.ph ... ask_id=693
For layers there's no such thing as a shared layer in DXF/DWG.
Choose "overwrite blocks" when pasting.
massimo
Post by massimo » Mon Jan 29, 2018 12:59 pm
Where do I find that? I search in Edit->Insert or in the application settings.
Post by Husky » Mon Jan 29, 2018 8:12 pm
The option bar pops up when you use e.g. Library/Insert or Clipboard/Paste
If not then you have to activate the option bar below ...
cadtec
Post by cadtec » Tue May 08, 2018 8:41 am
Hallo QCAD-Team
Wir sind ebenfalls sehr an XREF interessiert.
Beste Grüsse,
André
