Unable to remove black dot in drawing. (solved)
Jim0000
Post by Jim0000 » Sat Feb 10, 2018 12:05 am
I have a black dot on a line in this drawing. When I print it out, the dot becomes a larger circle. In this case, it is equivalent of around 30mm in the scale that the drawing is printed. The dot is on the line under #10. It looks insignificant on the drawing, but large on the printed version.
Can someone explain what this is and how I remove it please?
I will attach both a screenshot and a .dxf file of the drawing.
Elliptical tip panel.dxf
(97.16 KiB) Downloaded 81 times
Black dot mystery.png (16.66 KiB) Viewed 2184 times
lphilpot
Re: Unable to remove black dot in drawing.
Post by lphilpot » Sat Feb 10, 2018 2:04 am
It's a zero diameter circle on layer 0. I was able to window select and delete it...?
Len
QCAD Pro on Xubuntu Linux (usually)
Jim0000
Post by Jim0000 » Sun Apr 08, 2018 7:28 am
lphilpot wrote:It's a zero diameter circle on layer 0. I was able to window select and delete it...?
Ok, thanks Lphilpot.
Sorry for my late reply!
