Pure Inches not Feet and Inches
pmcvay
Post by pmcvay » Wed Mar 14, 2018 9:02 am
I'm new to QCAD (but am loving the program). Is it possible to set the measure dimensions, drawing dimensions, grid line dimensions etc to all be pure inches? For example, instead of showing 2'10'' show 34''. Everything I work with is 5 ft and smaller so pure inches is easiest for me.
Re: Pure Inches not Feet and Inches
Post by Husky » Wed Mar 14, 2018 9:36 am
Hi pmcvay - welcome to the QCAD Forum.
pmcvay wrote:I'm new to QCAD (but am loving the program). Is it possible to set the measure dimensions, drawing dimensions, grid line dimensions etc to all be pure inches? For example, instead of showing 2'10'' show 34''. Everything I work with is 5 ft and smaller so pure inches is easiest for me.
Yep - that is possible with QCAD. Use for an actual drawing the "Drawing Preferences" and/or for all new drawings the "Application Preferences" dialog below Menu/Edit.
Check the "Drawing Unit" register ...
... and the "Dimension" settings for "Dimension Label Format"
Grid settings are in the same corner ... :wink:
Post by andrew » Wed Mar 14, 2018 9:42 am
If you set the dimension format to "Fractional" you will get only inches (34) instead of feet and Inches (2'10"). The unit is not shown though.
pmcvay
Post by pmcvay » Wed Mar 14, 2018 9:47 am
Awesome, thanks andrew. That works great for dimensioning. I guess it's not possible for the grid lines and measuring dimensions then?
Post by andrew » Wed Mar 14, 2018 10:11 am
pmcvay wrote:That works great for dimensioning. I guess it's not possible for the grid lines and measuring dimensions then?
Not sure what you mean by "grid lines". The rulers at the top and left use the same configured format. So do the measuring tools.
Screen Shot 2018-03-14 at 09.09.45.png (107.68 KiB) Viewed 1543 times
