[solved] Layer line type only continuous
massimo
Post by massimo » Tue Jul 31, 2018 7:41 am
Running the recent Version 3.21.2.0 (3.21.2)
Creating a new file and changing the layer line type I can only select continuous. Where are all the other line types?
git build current origin/master, Gentoo Linux on amd64
massimo
Re: Layer line type only continuous
Post by massimo » Tue Jul 31, 2018 9:00 am
As we are installing from sources on Gentoo, I got this issue fixed by installing linetypes and themes directories.
https://bugs.gentoo.org/498656#c31
