Locating duplicate objects.
Miklstel
Post by Miklstel » Mon Feb 25, 2019 6:49 pm
I have some objects that have duplicate objects under them. Is there a way to locate these duplicates so I can delete them without selecting every possible object? Thanks
Miklstel
Re: Locating duplicate objects.
Post by Miklstel » Mon Feb 25, 2019 6:52 pm
I should I'm using ver 3.21.3.0 (3.21.3)
Post by Husky » Mon Feb 25, 2019 7:11 pm
Try ...
Menu/Modify/Detection/Detect Duplicates
Miklstel
Post by Miklstel » Tue Feb 26, 2019 12:06 am
Detection is not on my version. I have QCAD Community Edition ver 3.21.3.0 (3.21.3). Do I need to purchase? Thanks
Mike
Post by Husky » Tue Feb 26, 2019 12:16 am
In that case please post your questions in the Community Section. It makes it less confusing .... :wink:
viewforum.php?f=76
If you don't need the Pro functions then you don't need to buy the Pro Version. Here you can compare both versions:
https://www.qcad.org/en/qcad-documentat ... d-features
Post by Clive » Tue Feb 26, 2019 10:22 am
Hi Miklstel,
I have moved this topic into this appropriate forum, as Husky has mentioned, the Pro version has additional tools which you can take advantage of, it would be well worth trialing it.
Miklstel
Post by Miklstel » Tue Feb 26, 2019 2:54 pm
