How to change default line color
RogerM
Post by RogerM » Fri Mar 22, 2019 9:34 am
I prefer drawing with black lines on white background. QCAD default is opposite.
I can change default background to white but I cannot seem to change default line colour to black so each time QCAD starts I have to edit the line colour to black.
How can I change the default to black.
Thank you,
RogeM
Re: How to change default line color
Post by andrew » Fri Mar 22, 2019 10:00 am
The default color when starting QCAD is "By Layer", not white or black. So you're looking at the layer setup.
You can configure defaults for Layer 0 and new layers at:
Edit > Application Preferences > Layer > Add Layer
