How do i - get zig zag lines from AutoCAD to show properly?
Sjonnie
Post by Sjonnie » Thu May 30, 2019 2:28 pm
Hi All,
Introduction
I am trying to find a new CAD application on Linux since Draftsight (which I have been using for years) has decided to change their licensing model to a hefty €99,- per year even for home use.
For the last several months I have testing a number of CAD apps on Linux and QCAD (Pro) looks to be the best and most professional offering on the market. The licensing model (buy once - use forever) in combination with the price and upgrade policy is very reasonable to say the least.
Question
I am having a problem though with AutoCAD drawings using complex linetypes. Especially the linetypes zig zag and to a lesser extent batting. I cannot get them to show or print properly. I have set the "Display entities with more than..." setting to 5000 and even 100000 but still they pattern doesn't show. I have changed linetype scale to a variety of sizes and checked if I were in Drafting mode (which I wasn't). Still no luck.
QCAD preferences.jpg (91.66 KiB) Viewed 4041 times
The actual question :wink: :How do I get to display complex linetypes correctly?
Note that I have tried this with the latest trial version with the premium features enabled and disabled.
Why is this so important you might ask? Well, I have a large amount of drawings of various reconstruction projects of my house. All using complex linetypes like zig zag. I would really like to be able to re-use these drawings for other reconstruction projects in the future.
Looking forward to any suggestion you might have!
Warmest regards,
Sjonnie
Edit: Forgot to add the specs of the system:
Ubuntu 18.04 64 bit
QCAD 3.22.0.0
Build Date: Mar 1 2019
Revision: 2ba5a26
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
Greetz,
Sjonnie
Using QCAD Pro (Latest) on Ubuntu 18.04 64 bit
Re: How do i - get zig zag lines from AutoCAD to show properly?
Post by andrew » Thu May 30, 2019 2:45 pm
Do you have a (reduced) drawing file you can attach? Thanks.
Sjonnie
Post by Sjonnie » Thu May 30, 2019 2:49 pm
Hi Andrew,
Thank you for your swift reply!
I have added a drawing with two lines; one continuous and one zig zag (in red)
zig zag.dxf
(22.53 KiB) Downloaded 127 times
Greetz,
Sjonnie
Post by andrew » Thu May 30, 2019 2:57 pm
It looks like the linetype definitions in the file are broken.
Try this:
1. Misc > Modify > Reload Linetype Definitions
2. Select the red line
3. In the property editor, change the linetype scale to 1
Sjonnie
Post by Sjonnie » Thu May 30, 2019 3:01 pm
Hi Andrew,
Followed your steps; reloaded linetypes, changed linetype scale to 1 but to no avail :?
Saved the DXF and added it to this message.
zig zag.dxf
(22.53 KiB) Downloaded 116 times
Greetz,
Sjonnie
Sjonnie
Post by Sjonnie » Thu May 30, 2019 3:28 pm
OK, Not solved yet but it has got to be a problem/issue with the ltypeshp.cxf. I have studied the mm.lin and saw that the linetype was defined in there pointing to ltypeshp.shx. So I copied that over from my Draftsight install to /home/[username]/opt/qcad-3.22.0-trial-linux-x86_64/fonts. I then modified the file /home/[username]/opt/qcad-3.22.0-trial-linux-x86_64/linetypes/metric/qcadiso.lin to point to the shx file. No luck.
So what now? ;)
EDIT: I forgot to copy the accompanying shp file. So I copied that over and restarted QCAD. Unfortunately not solved :(
Greetz,
Sjonnie
Post by andrew » Thu May 30, 2019 3:42 pm
Works for me. Check you're not in draft mode (View > Draft mode unchecked) and not in screen based linetype mode (View > Screen-based linetypes unchecked). Make sure your installation is not messed up with copied / linked files from other software. This is something that works out of the box in QCAD Professional and does not need fixing.
If you can't fix, create a new drawing, draw a line and change it to zig-zag. If that does not work, your installation is broken and you need to re-install.
Sjonnie
Post by Sjonnie » Thu May 30, 2019 3:51 pm
Hi Andrew,
Tried your suggestions but no luck. I will remove the current installation and re-install. Keep you posted!
Greetz,
Sjonnie
Sjonnie
Post by Sjonnie » Thu May 30, 2019 4:03 pm
Hi Andrew,
Re-installing and using the trial version the DWG loads just fine. The problem seems to be in the Cripleware feature. So I have only one option: buy the Pro version ;)
Snip from the differences between QCAD and QCAD Professional:
[snip]
24 different line widths
47 built in linetypes
includes 9 complex linetypes with text / shapes
extendable through .lin files, .cxf files
35 CAD optimized line fonts
[/snip]
Greetz,
Sjonnie
Post by andrew » Thu May 30, 2019 4:39 pm
You didn't mention you were using the free Community Edition... Complex line types are indeed QCAD Pro only. I'll move to the correct forum.
Sjonnie
Post by Sjonnie » Thu May 30, 2019 4:48 pm
Just to state the obvious: after upgrading to the payed Pro version all is working as expected. :P
Happy camper over here. Now I only have to forget 30 years of AutoCAD experience :shock:
Greetz,
Sjonnie
Sjonnie
Post by Sjonnie » Thu May 30, 2019 4:52 pm
Well I didn't know until an hour ago that there were that much differences between the trial and the cripled version (where you have to delete a few *.so files). Mind you: I am happy to pay for the Pro version! I just had to be sure it did what I needed it to do; and it does! :wink:
Edit: Thanks for your support! It made me decide I had to have the paid Pro version! :)
Greetz,
Sjonnie
Panchdara
Post by Panchdara » Fri May 31, 2019 7:06 am
@Sjonnie, you've seen but the tip of the "support iceberg". Andrew, Husky and others provide unparalleled support for QCAD. You'll not be disappointed.
Best
Win 10, QCAD 3.24
