Can't quit the text edit mode
massimo
Post by massimo » Fri Jun 21, 2019 4:00 pm
Self compiled community version:
3.22.1.0 (3.22.1)
Qt Version:
5.12.3
Architektur:
x86_64
Compiler:
gcc 9.1.0
Hi, I remember on earlier versions, after entering text mode with Space, it was always possible to leave by pressing ESC, in order to continue with keyboard shortcuts like "eh" or "ev" . This is not possible here. ESC just deletes the current text edit field but does not quit. Every "eh" or "ev" does enter that string into the text field.
Only workaround is to click on some different toolbar to quit the text edit, then it's possible to type "eh"...
Is there any option to change that?
git build current origin/master, Gentoo Linux on amd64
