Trimming ARCs and LINEs
I'm trying to draw a developed view of a small sheet metal case.
How can I trim the little half- and quarter-arcs in the folding corners?
Christoph
Christoph
- Bildschirmfoto 2019-07-04 um 18.02.08.png (365.57 KiB) Viewed 8380 times
Christoph
Christoph
Re: Trimming ARCs and LINEs
Please have a look at this "Modify" tools:
Thanks. I looked at it but I have no idea as to
The attached screenshots are showing what I would like to achieve. Not that you think that I already managed to do so . I used Gimp to edit the screenshot to obtain the result.
- what menu topic I should choose between D2, B2 and AX
- which elements to click at which points
- whether to select an element first or not
Christoph
Christoph
Please refer to the user manual for step by step instructions for each of these tools, under Help > Reference Manual or online at:
https://qcad.org/doc/qcad/latest/reference/en/
I think the problem why I couldn't get ahead was that the line shape is a polygon. Can I resolve a PL into lines?
Christoph
Christoph
Are you using QCAD Professional or the free QCAD Community Edition?
OK, thanks. I'll move your posts to the appropriate forum for the QCAD Community Edition.
Thanks. Wasn't aware that I had been posting in the Qcad Pro section of the forum.
Back to the matter:
All the hassle I had and why I could not solve my problem intuitively with the suggested D2/B2 commands was, that my object was a PL (polyline) !
Thus my questsion in another thread how to resolve a PL into LI segments.
Back to the matter:
Christoph
Christoph
