Nested block not snapping or selecting
massimo
Post by massimo » Fri May 08, 2020 1:07 pm
This is the community version 3.24.3.0 (3.24.3).
If I have nested blocks, then sometimes I can't select the block or snap to point of that nested block when working in Model_Space. After editing the parent block of that nested block, then it also works from the Model_Space. Is that a known issue?
I have many nested blocks.
Community Version 3.24.3.0 (3.24.3), Gentoo Linux on amd64
Re: Nested block not snapping or selecting
Post by Husky » Fri May 08, 2020 8:15 pm
Please attache for further investigation the dxf drawing or at least an example dxf drawing which shows the issue. Thanks.
