(Solved) Small image
Roberto Vid
Post by Roberto Vid » Sat May 23, 2020 7:49 pm
Could anyone help me whith the image on my screen, when I open the dxf file converted, the image appears Very small like a point .
I use Anyconvert program to change dwg/dxf.
Thanks for any help.
Regards
RandallG
Re: Small image
Post by RandallG » Sat May 23, 2020 8:09 pm
Can you please upload the drawing file so we can have a look at it to see whats wrong?
Also, what version of Qcad are you using. And on which Operating System?
Thanks.
Roberto Vid
Re: Small image
Post by Roberto Vid » Sat May 23, 2020 9:53 pm
Hi,Thanks for fast awnser,
I use Community edition, Windows its my system. Ithink to be using last version.
Regards
AnyConv.com__01- TÉRREO E JIRAU ESGOTO - AVENIDA MERITI - R7.dxf
(2.48 MiB) Downloaded 28 times
Re: Small image
Post by CVH » Sat May 23, 2020 10:53 pm
There is a major part at about -685300;-7460600
and 56 atributes at the origin.
Qcad auto zoom on load includes all these entities. :wink:
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Re: Small image
Post by Husky » Sat May 23, 2020 10:54 pm
long story short: That drawing is a challenge. Maybe the converter program messed it up but I'm not sure about it.
Howsoever - you can bring it back to a working condition with QCAD. Is this what you are looking for?
Roberto Vid
Re: Small image
Post by Roberto Vid » Sat May 23, 2020 11:52 pm
Hi Husky, thanks for awnser
Yes, I am looking for a way to fix that .
Regards
Re: Small image
Post by Husky » Sun May 24, 2020 12:13 am
What I did:
I thawed the frozen layer,
I adjusted the drawing units,
I fixed the invalid block names,
I deleted everything outside the drawing frame,
saved it under a new file name.
Except the frozen layer you can handle that with the Community Edition too but it is easier with QCAD Professional. :wink:
Have fun!
Roberto Vid
Re: Small image
Post by Roberto Vid » Sun May 24, 2020 10:44 pm
Hi Husky
I Followed your instruction, (deleted everything outside the drawing) and the problem was fixed.
Thanks a lot, Very Very glad.
Regards
RandallG
Re: (Solved) Small image
Post by RandallG » Sun May 24, 2020 11:31 pm
Thank you Husky (and CVH and Andrew of course) for always being a great help here to all of us in need. Appreciate the help and fast responses.
Roberto Vid
Post by Roberto Vid » Mon May 25, 2020 12:50 am
Hi all,
I'd like to thanks all suport people, read Andrew, Husk, CVH, RandallG and all forum components. I have had here very help about QCad, when I need suport, all users have help me. I am an retired Engineer, use Qcad for calculate buildings materials, Sorry sometimes its hard for me to explain anything wrong, cause I am New QCad user ( I worked with AutoCad and DraftSight) and my First language its Portuguese, I don't have used English for long time.
Thanks all
Regards
