(Solved) Differents caracters
Roberto Vid
Post by Roberto Vid » Sat May 23, 2020 11:31 pm
I still getting problem whith fonts. When I change DWG to DXF, some letters do not come correctly, for example:
The letter Ç, ã, â, any letter with different caracter Appear ??, For example: these words in portuguese:
1- INSTALAÇÃO. APPEARS INSTALA??O
2- SERÁ APPEARS. SER?
3- 1°. APPEARS 1?
Thanks for any help
Regards
Re: Differents caracters
Post by Husky » Sat May 23, 2020 11:52 pm
How your text is displayed depends on the Text Font and should not be related to the dxf or dwg format.
In short: A Text font is a set of character. Each character is associated to a key or key combination on your keyboard. If you hit X then the associated character should be X too and is displayed in your text as X. But if the X is missing in the font your text will display ? for a missing character.
To solve your issue you need to find a text font which represent all of your needed character.
Roberto Vid
Post by Roberto Vid » Sun May 24, 2020 12:08 am
I will be buying pro soon, but before I would like to test once more. How could I to reverse the community edition in pro.
Regards
Post by Husky » Sun May 24, 2020 12:16 am
Restore the deleted files from the Recycle Bin or reinstall the trial again.
Roberto Vid
Post by Roberto Vid » Mon May 25, 2020 7:06 pm
Hi all,
I changed the conversion program DWG/DXF, and got a good Work.
Thanks all
Regards
