[solved] changing the text height in dimensions
thomasgog
Post by thomasgog » Tue Dec 22, 2020 8:52 pm
I am a newcomer to qcad and this question has probably been asked before:
How can I change the text height in dimensions to match the overall looks of the drawing ?
(I'm using the QCAD Community Edition, Version: 3.25.2.0 (3.25.2) under Windows 10)
Thank you
Re: changing the text height in dimensions
Post by CVH » Tue Dec 22, 2020 9:15 pm
For the actual drawing: Menu .. Edit .. Drawing Preferences .. Dimension .. Dimension Settings .. Text height (Ctrl+I)
In general for new drawings see similar but under 'Application Preferences' (Ctrl+,)
There is a lot more one can customize. :wink:
thomasgog
Post by thomasgog » Tue Dec 22, 2020 9:16 pm
... never mind, I figured it out.
... using the "Scale" parameter in the Property Editor
thomasgog
Post by thomasgog » Tue Dec 22, 2020 9:18 pm
Thanks a lot, CVH. That's even better
Post by Husky » Tue Dec 22, 2020 9:34 pm
Topic moved to QCAD Community Edition.
Re: [solved] changing the text height in dimensions
Post by CVH » Thu Dec 24, 2020 5:48 am
Thanks Husky.
That option scales more as the text alone !
