Hello (Newbie Alert)
Using the Rectangle Tool I clicked on the first point and entered the following coordinates: @7 5/8",4'-6 3/8
But when I use the dimension tool the I get 7 5/8 which is correct but instead of 4'-6 3/8 I get 3'5 5/8
Any clue is welcome.
Using QCad Community 3.26.4 on Winodows 10
Drawing unit: Inch
Paper unit: Inch
Measurement system: Imperial
Dimension Settings > Label Format >
Format: Architectural
Precision: 0' -0 1/16"
[solved] Entered Rectangle coordinates at command line but dimensions are different
- Registered Member
- Registered Member
Re: Entered Rectangle coordinates at command line but dimensions are different
I figured it out. Coordinate inputs where incorrect of course. Using the following worked
@7 5/8",-4'6 1/2
@7 5/8",-4'6 1/2
