Some DXF files are displayed incorrectly
Ruslen
Post by Ruslen » Fri Apr 01, 2022 12:13 pm
Some DXF files are displayed incorrectly, the scale has changed, and the dimensions have disappeared. I open the same files in different programs, and get different results.
Missing dimensions and holes shifted
all OK
The scale has changed
eDrawings 2020 x64 Edition.png (46.79 KiB) Viewed 8639 times
all OK
DWG TrueView 2021 - English.png (48.62 KiB) Viewed 8639 times
[attachment=5original file .DXF[/attachment]
all OK
all OK
eDrawings 2020 x64 Edition.png (52.9 KiB) Viewed 8639 times
all OK
DWG TrueView 2021 - English.png (63.44 KiB) Viewed 8639 times
Накладка АТЗКН (3,0 мм Ст3) - 40 шт.DXF
original file
(24.83 KiB) Downloaded 357 times
Re: Some DXF files are displayed incorrectly
Post by Husky » Fri Apr 01, 2022 7:22 pm
... the scale has changed, and the dimensions have disappeared.
Sorry - so far I can't reproduce the issue. There are no dimensions in the drawing, except a dim as a block for what ever reasons. I tested the drawings in different programs - all show the same result. I can't say anything about a scale of a drawing without the info what the correct dim would be. Please check my screenshots and tell me if the dim is accurate or not.
Post by CVH » Fri Apr 01, 2022 9:16 pm
First file I get: 176.6000 // 112.0000 // 65.7660
Second: 120.1500 // 121.267094 // 16.422109
It seems they all match exact.
In the picture with the shifted holes I can detect dimensions in a very small text size.
The shift itself I can not reproduce.
Post by andrew » Fri Apr 01, 2022 9:51 pm
Ruslen: I think you are using the QCAD Community Edition. I've moved this topic to the correct forum.
