opennurbs: IsUnsetPoint has been removed
Posted: Sun Apr 23, 2023 4:53 pm
Compiling QCAD against opennurbs v7.11.21285.13001 aborts with the following error:
and this is normal because IsUnsetPoint has been removed.
math/RSpline.cpp:1051:11: error: no member named 'IsUnsetPoint' in 'ON_3dPoint'
if (p.IsUnsetPoint()) {
math/RSpline.cpp:1916:5: warning: 'qSort<QList<double>>' is deprecated: Use std::sort [-Wdeprecated-declarations]
qSort(keys);
/usr/local/include/qt5/QtCore/qalgorithms.h:188:1: note: 'qSort<QList<double>>' has been explicitly marked deprecated here
QT_DEPRECATED_X("Use std::sort") inline void qSort(Container &c)
/usr/local/include/qt5/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X'
# define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text)
/usr/local/include/qt5/QtCore/qcompilerdetection.h:675:55: note: expanded from macro 'Q_DECL_DEPRECATED_X'
# define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text)))
