How to get the containing rectangle of text in a DXF file
Re: How to get the containing rectangle of text in a DXF file
Post by CVH » Thu Nov 02, 2023 6:23 am
WildWolfCJ wrote:
Thu Nov 02, 2023 3:41 am
HI CVH
I did not find the usage of the -enable-script-debugger parameter.
Odd, when I plug in the search term "-enable-script-debugger" in the forum search I get 65 hits.
Among those: 3 years back I listed an overview of QCAD start up arguments:
https://www.qcad.org/rsforum/viewtopic. ... ger#p30840
WildWolfCJ
Post by WildWolfCJ » Thu Nov 02, 2023 7:05 am
HI CVH
Thank you for your answer. I just tested the -enable-script-debugger parameter, but no debugger interface appears? I would like to ask you how to debug JS code? Don't need single-step tracking?
Post by CVH » Thu Nov 02, 2023 7:37 am
The debugger would pop up when there is an error or at the point in the code where you included debugger;
But as said: Never tried it in command line mode.
For some reason the UAC does not allow me to address QCAD or one of the folders from the OS command line.
Lets go back to:
WildWolfCJ wrote:
Wed Nov 01, 2023 9:09 am
I have successfully implemented this function according to your instructions. Thank you very much for your help.
One could halt that script before printing.
    debugger; // Halt script before printing the string when QCAD is started with -enable-script-debugger
    // Export the composed string:
    print(texStr);
WildWolfCJ
Post by WildWolfCJ » Thu Nov 02, 2023 8:00 am
The reason is that for some reason the UAC does not allow me to address QCAD from the OS command line.
Lets go back to:
    print(texStr);
Thank you for your patient answer, I already understand the role of -enable-script-debugger
Post by CVH » Thu Nov 02, 2023 8:07 am
For the future:
Hit the Reply button and when composing your reply/question select a part in another post before hitting the Quote button there.
In that way you only include the intended paragraph you want to quote instead of quoting whole the post each time.
That would make your topics more readable. :wink:
Return to “Chat”
