[solved] qcad 3.18 get forces closed every open .dxf or dwg files
ahmadraniri
Post by ahmadraniri » Sat Jan 20, 2018 11:44 pm
hi' sir.... very glad when I found there was an opensource cad software in 2015, yeah... Qcad...
but when I move to linux ubuntu 17.04 then install Qcad 3.18, I found a bug, I get forces closed every open .dxf and .dwg file... I draw and save the files using qcad too before...
Os: linux ubuntu 17.04
vers: qcad 3.18
DE: LXDE
thanks for attention.
ahmadraniri
Re: qcad 3.18 get forces closed every open .dxf or dwg files
Post by ahmadraniri » Mon Jan 22, 2018 9:55 am
case closed... solved after upgraded to 3.19.2 version, thanks... May Allah show you all his way... :D
Return to “Chat”
