Inch symbol in dimensions
ethatch
Post by ethatch » Tue Dec 18, 2018 12:06 am
How do I get the inch symbol (") to appear behind the dimensions in my drawing?
I'm using windows 10
Qcad version 3.21.3.0 (3.21.3)
Inch symbol.JPG (16.47 KiB) Viewed 790 times
TSG
Re: Inch symbol in dimensions
Post by TSG » Tue Dec 18, 2018 10:34 am
After selecting a dimension you can edit specific properties in the Property Editor.
When you change the Label from Auto to <>" you will get the desired result.
The <> is a placeholder and it will be replaced by the value of the measured dimension (in this example by 60,37)
Before and after the placeholder you can place any text you want.
Thomas
Return to “Chat”
