I have a number of library packages of useful things. But when I start Qcad up, there is a considerable delay in the process while Qcad seems to be updating the library data. This quite a long delay. Is there a way to speed this up once the library has been loaded once. Is there some mechanism to cache the formatting information for faster loading?
Loading library
Re: Loading library
You can find the Library Browser settings for synchronization within the Application Preferences:
Re: Loading library
Thanks for the quick and useful response.
- charles
- charles
