dimension length scale
hiqserv
Post by hiqserv » Wed Jun 05, 2019 3:07 am
Thanks, for the previous help!
When I dimension an object that is not full scale, the dimension value is also undersized. example, a block 1" square , one/fourth scale, the dimension is 0.25. Autcad has a command called DimLfac. that multiplies the dimension by the scale factor. Can I do the same thing in QCad?
Re: dimension length scale
Post by Husky » Wed Jun 05, 2019 4:02 am
After launching a Dim an option bar will pop up ....
Post by andrew » Wed Jun 05, 2019 9:37 am
You can also adjust the linear scale for existing dimensions using the property editor (property "Linear Scale").
hiqserv
Post by hiqserv » Wed Jun 05, 2019 4:41 pm
Thank you once again! The tech help is great, I have used a lot of CAD software over the years, but this is great, and like the open source. Am I missing a manual ? the help area never seems to help that much? Maybe there is a third party manual like QCad for dummies?
One more question: How can I select one entity or dimension with out using the select boxes? I would like to just click on something and have it selected.
Post by andrew » Wed Jun 05, 2019 5:24 pm
Have a look at the QCAD book:
https://qcad.org/en/documentation/the-qcad-book
Yes, a simple click on the entity will do.
Return to “Chat”
