Change the appearance of lines
Harperdave
Post by Harperdave » Wed Oct 30, 2019 9:06 pm
I am a "light" user and limited in skills so far. (Using QCAD Pro.) Can anyone explain simply, a way to change the appearance of lines? "Layers" and some other things are still Greek to me. I am avoiding using colors, but I would like to be able to use dotted and dashed lines, as an example, to show the position of overhead objects. Thanks in advance for the help.
Re: Change the appearance of lines
Post by CVH » Wed Oct 30, 2019 10:20 pm
I would start here:
https://qcad.org/en/tutorial-working-with-layers.
https://qcad.org/en/tutorial-layers-blo ... attributes.
Beside that you can set these individual for most kinds of objects.
https://qcad.org/en/tutorial-property-editor
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Harperdave
Post by Harperdave » Thu Oct 31, 2019 2:52 pm
THANKS! I get it now. As usual, it's easy when you see it. "Linetype Scale" was my issue. The scale was too small to see the changes. (DUH)
Appreciate the help!
Return to “Chat”
