There was an option on the Quick links menu to show only unread posts, but it's no longer there. In fact I had bookmarked that link:
search.php?search_id=unreadposts
It was an easy way to quickly see what's new. Now when I go there, I get "The requested page could not be found." Is there a new place to see all unread posts?
Thanks.
Edit: I just realized this should've gone in the Site Feedback board. Sorry about that.
Has the QCAD forum changed?
Len
QCAD Pro on Xubuntu Linux (usually)
Re: Has the QCAD forum changed?
Yep - same here!
Found an explanation by accident:
andrew wrote: ↑Sat Nov 02, 2019 10:11 pmThere's currently a DDoS attack underway on our server, mostly using the forum search functionality in an attempt to bring the server down by triggering lots of CPU / DB intensive queries. Forum search has been disabled for now until the attack is over. Luckily the rest of our infrastructure can easily cope.
Probably Autodesk lol... kidding
My apologies. Everything should be back to normal. DDoS attacks are slightly annoying but luckily not much more than that.
Feels like home again.
