Has the QCAD forum changed?
lphilpot
Post by lphilpot » Sun Nov 03, 2019 3:56 pm
There was an option on the Quick links menu to show only unread posts, but it's no longer there. In fact I had bookmarked that link:
search.php?search_id=unreadposts
It was an easy way to quickly see what's new. Now when I go there, I get "The requested page could not be found." Is there a new place to see all unread posts?
Edit: I just realized this should've gone in the Site Feedback board. Sorry about that.
Len
QCAD Pro on Xubuntu Linux (usually)
Re: Has the QCAD forum changed?
Post by Husky » Sun Nov 03, 2019 6:42 pm
Yep - same here!
Found an explanation by accident:
andrew wrote:
Sat Nov 02, 2019 10:11 pm
CVH wrote:
Sat Nov 02, 2019 9:03 pm
Odd is that all these got recently missing...
Searching
Advanced search
Search members
Search post
Search anything
There's currently a DDoS attack underway on our server, mostly using the forum search functionality in an attempt to bring the server down by triggering lots of CPU / DB intensive queries. Forum search has been disabled for now until the attack is over. Luckily the rest of our infrastructure can easily cope.
Post by John Hyslop » Mon Nov 04, 2019 4:22 am
Probably Autodesk lol... kidding 😉
Post by andrew » Mon Nov 04, 2019 8:46 am
My apologies. Everything should be back to normal. DDoS attacks are slightly annoying but luckily not much more than that.
Post by Husky » Mon Nov 04, 2019 8:53 am
Feels like home again. :D :D :D
Return to “Chat”
