position of drawing in PDF
p.raut
Post by p.raut » Tue Nov 05, 2019 8:14 am
Hi there,
When I draw something and export it as PDF file, the drawing is at the leftmost bottom. I tried to centralize or put it in top rather than bottom but Could not. There must be some way of doing it, looking forward to reply.
Re: position of drawing in PDF
Post by Husky » Tue Nov 05, 2019 8:27 am
please refer to this tutorial - I'm pretty sure it will help you to find the correct print settings.
https://qcad.org/en/tutorial-printing
Return to “Chat”
