[SOLVED] Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
Post by John Hyslop » Wed Nov 20, 2019 6:23 am
Hi All
I'm having trouble nesting these parts, could anyone help out here..
Best Regards
NestTest-After.dxf
(208.19 KiB) Downloaded 72 times
NestTest-Before-NoDims.dxf
(208.09 KiB) Downloaded 70 times
Re: Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
Post by Husky » Wed Nov 20, 2019 7:27 am
QCAD/CAM can't identify the proper shape of the largest part. The 20 mm Circle on the very left side needs a bit of trim work ... :wink:
After that is fixed a result could look like this one:
Post by John Hyslop » Wed Nov 20, 2019 10:26 am
Hi Husky
Oops... Thanks for that...I did these parts when I 1st started using qcad I think I must of trimmed to vertical construction line through centre of arc...
Good pickup..I should of looked at that seeing as it seperated it when nested 😁
Re: [SOLVED] Help testing Trial QcadCam Version: 3.23.0.0 (3.23.0)
Post by John Hyslop » Wed Nov 20, 2019 12:11 pm
When my year is up I'm definitely going to upgrade to qcadcam just for the nesting feature.. it's brilliant...
Return to “Chat”
