Computer requirements
larry.hill
Post by larry.hill » Sat May 16, 2020 12:24 am
1. What is the computer system requirements to run Qcad?
2. What size files can Qcad handle?
Thanks in advance for your response.
Larry
Re: Computer requirements
Post by Husky » Sat May 16, 2020 1:50 am
https://qcad.org/en/faq
Note: That is minimum - everything "faster" will help you at your daily task ... :wink:
Depends partly on your hardware. I run a standard Win10 computer but with a higher RAM size (16 GB). Nevertheless I try to avoid file sizes over 10 MB ...
Just to be sure I recommend to use the trial offer for a solid evaluation. It' free of charge ... e_surprised
https://www.qcad.org/en/qcad-downloads-trial
Return to “Chat”
